Simplistic NJFET RIAA
See pic of the grounded end. It's totally conductive—makes direct contact with the outer metal fitting once the connector is all screwed together...
Hello guys, I need some help in troubleshooting in my 2015 FSP.
I have done the below and my analysis.
Please let me know on any other suggestions on where to check? Or possibility on other problems?
Only Q1 is populated, aiming for ~57db gain
Ch1
Only d1-4 no light
Q7 ds resistance is 17ohm
Q3x & Q5x, ds resistance is 77ohm
Q4x vbe is 0.79
Rail and input dc is 44v & 38v.
Between Tp1 & tp2 is -0.07v
- Suspect K117 at Q7 is gone, thus D1-4 not lighted and thus cannot bias and seeing TP1/2 voltage above.
Puzzling ch2
Input 51v
Rail is 22v, cannot be adjusted via VR2x
All leds lights
Bias between Tp 1 & tp2 can adjust to 3-4 via VR2x and VR1
Q3x & Q5x, ds resistance is 15ohm
Q4x vbe is 0.79
Q1x warmer than q6x
- Suspect K117 at Q3x & Q5x is gone thus Rail voltage got stuck.
diyAudio Chief Moderator
Joined 2002
Ch1 Q7 most likely gone or there is some problem at its solder joints. Q3x Q5x measured at 77 Ohm RDS is reasonable.
Ch2 Q3x Q5x suspects yes, remove them to confirm RDS & IDSS, but before that see if Q6x is the reason. Measure its VDS. 3-4 VDC is normal. Confirm R3x's value also.
Joined 2017
being at one of those so simple steps, not seeing the solution...
Hi again
I am anxious I could bungle the connection of my trannies to the raw PSU...
I have two TTSA0030 Audiograde 2 x 16V 30VA to connect. They're dual secondaries.
I connect them in series, right? Anything I should take special care of (like, polarity)?
Has anyone a sketch/foto/schematic available onto which I could have a peek?
Thanks, and happy weekend!
david
Joined 2002
Connect the second with the third wire of the four secondary ones. The first and fourth free remaining wires are the new summed secondary ends.
For example a label states SEC 1 are the red & black wires, SEC 2 are the yellow & orange wires. You tie together black & yellow. The free remaining red & orange are your new series secondary with double the voltage.
Joined 2006
Ah, perfect!
So 1 white + 1 brown go together, the other to the psu...
They still need to be in series and that is tricky with same coloured secondary's. Connect a brown and white together and measure the output voltage before connecting to the power supply. If you get 2 X the secondary AC voltage you are good. If you see less or very little AC then change just 1 of either the brown or white to get them in series.
Joined 2017
Thank you, TUM!
I did so and the results are weird:
I connect the inner secondaries (orange-grey) and get 0.003v
I connect two outer secondaries (orange-grey) and get 0.0v
Faulty dmm or anything else?
