Germanium investigations
It is good to measure germanium transistors with the Chinese TS-1.
The tester even shows reverse currents.
Transistor ГT404Г:
Yes, I've use same kind of tester but there are some limitations for some Big Germaniums. They indicate C or damaged parts or unknown parts. However measurements using DMM is good. For small signal parts Ge are okay as well as all BJT, Jfets, Mosfet, Diodes and Capacitors.
@ Coolnose
Normally Ge provide less gain..
It's depend on point of view if you don't need for external preamplifier additional stages
and can use passive volume control, then 3 or 4 active stages (input impedance buffer included)
such " integrated " power amplifier stays in minimalistic class A style :^)
