Acoustic Horn Design – The Easy Way (Ath4)
TNT
Yes, of course, since there isn't much pinpoint imaging to be had in a concert hall it's natural that you would not care much about imaging. But those who are familiar with the strong imaging that can be achieved in a studio, this tradeoff is not acceptable to us. This is precisely my point about biases due to musical preference.
What you want to achieve, the "I am there" result is not likely to ever happen with two channel since this setup can never recreate the acoustics of a large hall. You will need multichannel to do that.
But the fact is that multichannel has never and likely will never "take-off." The music business is two channel, that is the medium and it does musical art with that in mind, which works extremely well for studio work. It is, I agree, a total failure at "I am there" - as you say "So no sacrifice for me."
This is exactly what the simulation predicted and that was what I wanted to achieve with this waveguide, so yes, I'm happy with that, but I could live with somewhat lower DI for sure. I'm not so sure about an even higher DI. This is around 10 dB where it's flat. I'm still not sure about an optimum, if there's any at all.
The higher the DI the greater will be the delay time between direct sound and the VER and reverberation. This will enhance the perception of image since image requires as clean a direct sound as is possible. This idea comes from studies which show that high DI improves intelligibility in reverberant spaces.
A low value of DI, CD or not, will enhance spaciousness, but sacrifice imaging. This may be an acceptable tradeoff for many, but not someone who prizes imaging.
What kind of DI would you aim for in a multichannel (immersive) environment? And would you differentiate between the LCR and the rest of the speakers in this regard?
BTW, I noticed a question somewhere on the previous pages why I do this in the first place. Well it's because I owned several loudspeakers with waveguides of similar properties in the past I and liked the sound very much - the better the waveguides the better it sounded. It simply works for me. I like the wide sweet spot, the unlimited dynamics and unprecedented neutrality and transparency of all sounds it reproduces. And you know what? For what it can do it's fairly cheap after all.
10", 12" and 18" OSWG. The latest 13" OS-SE sandhorn is better than any of them. I just wasn't able to get to this level of performance without the numerical design and simulation we have now. I also didn't fully appreciate how essential is the smoothness of the mouth termination, for any size.
There's absolutely no point in doing steady state measurements at listening position. That's not what you hear in the end and that's the reason you won't see them in this thread - at least not made by me. That's not the kind of measurement useful to evaluate the quality of any sound source and you should know better.
It's not useful to evaluate the difference of waveguides at listening position??
Please educate an idiot like me😉
No, that's not how your ears and brain work. It's not like a single microphone doing a steady-state RTA. That's the reason the loudspeakers must be measured separately, even if they are listened to in a room full of reflections in the end. And how an anechoic response of a good loudspeaker should look like we know for a very long time.
I must say that I have had increased satisfying result re: fidelity as I have started to measure in listening position and EQed that to more linear. Now, I use low DI speakers, probable quite CD (haven't measured) - don't know if that "helps"..
