BK Electronics mosFET 100 watt modules
Was looking but only found the 75W (100W?) one.
It uses the same board just lower power supply and lower voltage Mosfets (2SJ48/2SK133)
Yeah both shot one jumping all over place then goes open the other reading 6 max should be 50 plus so changed. Glad I pulled em and tested out of circuit. I'll change the other two as well. Hopefully fingers crossed tomorrow I can just get all parts in then hooked up and take readings tried again today but more distractions hence just getting two transistors done ew.
Hi suzyj,
Not to pick a fight, but I wouldn't call 3 to 6 times higher supply voltage, to be 'slightly higher'. The typical op-amp sports +/-15V rails; audio power amps are more likely to be +/-40 to 90V.
And maybe it's just me, but I think of 3 to 10 amps of output current to be more than just 'beefier', than 10 to 40 milliamps.
Then there's the availability of '+' and '-' inputs, and typically over 70dBV open loop gain.
But the 'real' difference, is that the term "op amp" has become widely-agreed-upon to refer to a Monolithic Integrated Circuit, with relatively high-impedance inverting and non-inverting inputs, and excellent PSRR, da da, da da ..
Not that there's anything much to be accomplished by my nit-picking .. But it does seem (to me, at least 😉) like agreed-upon terms save time and mental effort -- especially in a field with this much complexity. 😀
On another subject, from post 103 (thanks for the research and post RS232) is it just me, or are these Vgs labels backwards? .. or perhaps suffering some other indignity that I'm not smart enough to sort?
Cheers
No, silly. I have power amps at work. They occupy multiple 19" racks, run at 22kV, and require a whole building full of chillers.
These little things are opamps. Just because we typically design the negative feedback network onto the PCB doesn't mean they don't have a negative input.
Think of it in dB terms. You can get perhaps 500mW out of a monolithic NE5532. Put a couple of dozen in parallel and you've got ~5W, or 10dB more. 50W is just another 10dB, and 500W is just 10dB on that.
And doesn't _everyone_ design their amps for >100dB open-loop gain, high PSRR, high input impedance and low offset?
OK, I'll happily concede your point concerning scale. Wouldn't mind a peek at those 19" racks -- or the electric bill! 😉 22kV, huh? Wonder how many folks herein are thinkin' in those scales, though ..
So .. I guess your hypothesis (if that's the right word 😱) is that a 20 or 30dB difference in power output doesn't deserve a different *classification*? .. or monolithic either?
Cheers
Actually speaking seriously my rationale is more around the design process. For me the design process for an opamp is exactly the same as that for an audio power amp. As I said before, I just use a slightly higher power supply voltage and more robust output devices. Everything else is the same from a design perspective - gain, offset, input impedance, CMRR, PSRR, noise, stability.
Thinking power amps are somehow special (or even worse, that you can skip things because the output is higher power) is not useful.
At my work I am lucky enough to have a pair of very large klystron microwave amplifiers (and a whole lot of smaller ones) that _are_ special. And incredibly cantankerous. Though I did diagnose in a tetrode-based HV power supply by modelling it in LTspice recently, so there's that.
Forgot now setting up bias using this configuration you need to remove the inductor? Plus it uses the pins for measurements. Now those pins obviously don't tally with mine so anyone know what pins are for what think 1 -5 or 6. Obviously 2 go to the fuses. Where do the other two transformer leads go too on this one?
Found the article on the 100/150W amp (8/4 ohm) from maplin and like I said it's the same thing just higher power Mosfets (J50/K135 instead of J48/K133) and higher power rail +/-55 Vdc (+/-58vdc max)
To setup bias you don't need to remove anything from the board just to add the 100R before the fuse.
The numbering on the board is easy to follow it's just supply rails (+/-) input and output
1- Output
2 - + supply
3 - Input
4 - ground
5 - - supply
Your module(s) are clearly marked so you shouldn't have any problem in compare the 2.
About the gate resistors, well I'm no expert (and someone will jump in soon) but it all depends on the design and voltage/current need to feed the Mosfet but on the Hitachi application note the 100W amp only has 100r and the 50W one none at all.
Hope someone jumps in to give a better explanation.
Yeah not sure i need to mess around with the 100r resistors connected to fuses etc. Just want to set bias via the trimmer as that is all it will need. The other checks mentioned prior are more for if you are building from scratch. This is fully built so it's just getting the mA across fuses to around 100mA and the outputs between 0v and max 100mV. All I've changed is the trimmer. So for instance it says connect fuse 2 to pin 5 which is -ve supply etc etc all that's installed and soldered in so I just need to trim and measure across the fuses and +/- supplies. Its says 50mA but I'm sure this would be fine at 150mA. Plus it says rotate trimmer fully clockwise I would have though it would be full ccw highest resistance going to the mosfets.
If I go full cw then it will just be the gate resistors holding back the current. Unless I'm looking at my tracks on the pcb wrong.
Just don't forget to add a heatsink to the mounting brackets because they are not enough to remove the heat from the power mosfets.
PS: according to the App note your power supply is fine for those 2SJ50/2SK135 mosfets and 80 to 120mA bias
