@thor2, I will invite you to participate in my upcoming cable blind test over at audiosciencereview.com , where some 5m of an ultra-junk giveaway RCA cable will be compared with a short (5cm of silver wire), or something along these lines of "extreme" cable difference. This will be the place where you can actually prove you're not just making fun of us, seeking attention, stealing our time.
Just him and not A 8?@thor2, I will invite you to participate in
Did you see the links I gave to my measurement effort? Using real music signal. I will add the found residual for download, so you all can hear for yourself what the -130dB(!!!, again) difference between the cables sounds like.Generally I think the complexity of music signals are beyond what we use to measure performance, even std IMD measurements are 2 tones but still differ quite a bit from a single tone in terms of measured distortion so maybe there would be more measured differences if you could measure 10 or 50 multi tones at the same time.
Thanks for the invitation, but must refuse, I have participated in plenty of blind tests and various other tests which prove that there are sound differences which can't be measured with certainty, now it is time to find out why and how.@thor2, I will invite you to participate in my upcoming cable blind test over at audiosciencereview.com , where some 5m of an ultra-junk giveaway RCA cable will be compared with a short (5cm of silver wire), or something along these lines of "extreme" cable difference. This will be the place where you can actually prove you're not just making fun of us, seeking attention, stealing our time.
I know, but indra1 asked and I answered with the addition of a few practical examples.You are just repeating the same argument which has been explained at the beginning of this thread.
You still do not understand my point. Hearing is not the same for everybody, but measurement is repeatable. What you can hear may nor be audible to me or somebody else. When you can hear a difference the measurement will tell you the significant value important for you for good sound. But that value may not be significant or of good sound for me.... True, but no one can know how the capacitors sounds from measurements. Only with the ear and brain can it be decided...
@thor2, I will invite you to participate in my upcoming cable blind test ...
What about adding analog_sa?Just him and not A 8?
I can predict that they will say your equipment's resolution doesn't suffice or something like that after they didn't hear any difference in the DBT.
Best regards!
Single blind test isn't double blind test. Not proof but anecdote.Thanks for the invitation, but must refuse, I have participated in plenty of blind tests and various other tests which prove that there are sound differences which can't be measured with certainty, now it is time to find out why and how.
Plural of subjective impression is still subjective impression. They don't go into metamorphosis and become objective evidence as if caterpillar turning into butterfly.I know, but indra1 asked and I answered with the addition of a few practical examples.
That already has happened with the first, sighted listening test I've put up at ASR, gathering impressions before even starting the blind testing. Notably from the guys from the German forum where the BT didn't happen for thread moderation issues. You know, the same guys that are heavily engaging in even more weird stuff like cable sound, stuff like this (impact of mains fuses, even their directionality) : Tuning durch Feinsicherungen - Seite 6 - aktives-hoeren.de (sorry @all for linking to a German discussion).What about adding analog_sa?
Best regards!
What about Jakob2? He is in Germany, at least according to his forum ID.^ Everybody, notable the believers (no disrespect) is invited, of course. The larger the probe count, the better.
Cable-Test is online : KSTR Cable Test #02 (analog RCA loopback) | Audio Science Review (ASR) Forum
Becoming a member at ASR is easy, so don't feel shy, Golden Ears ;-)
Music signals are beyond comprehension. You just don`t describe signals. Some brave souls truly believe that a meaningful representation with primitive methods is possible. But hey, take it for what it's worth: entertainment.
We 'cable believers' must probably recognize the zero test as a total test, but still with weak points.
If the cable / component is tested as Ethan Winer shows, it will be with a standard interface which does not necessarily correspond to what the cable will be exposed to in 'a real hi-fi environment'.
Entertainment. That's what I'd also say if I absolutely had no clue of science.
Btw, I've found a video by PS Audio where this man tells anecdotes quite in an entertainer's manner.
Ethan Winer describes a low impedance source and a high impedance sink. Isn't this what HiFi gear provides?
As he said and we all (should) know, with the exception of TT interconnects, 'cause MM carts significantly rely on proper (cabling plus input) capacitances.
Best regards!
Best regards!
- General Interest
- Everything Else
- Sound signature
