С не симметричным/не балансным входом, чип ковыляет на одной ноге! Ты этого не заметил? Там так колбасят помехи и т.п. при не балансном включении.
With an unbalanced / unbalanced input, the chip waddles on one leg! Didn't you notice that? There are so many interference, etc. when not balanced.
I read it.Read 99 times, if you don't understand - another thousand
Sorry to interrupt, I've had a hiatus of about a year in my hobby projects / time to read up on forums because of Covid-19, quarantine in the family, life, work and all that jazz.. :-/
I've just ordered from 3E Audio the 1x480W TPA3255, 2x260W TPA3255, and the DSP ADAU1701 board - for fun.
I'll use a Connex SMPS 600 RS to power all of this.
This all combined should power a single 3-way speaker, with the DSP doing the crossover.
If I ever get this speaker / amp / dsp combo to work out right, I'll of course build it's brother to make a stereo pair.
Does this sound okay to you guys or can you shoot holes in my approach right now already..?
This one looks like it might be OK: TPA3255 2x260W 2Ch Class D Audio Amplifier|Amplifier| - AliExpress
Another hobby
I just downloaded the picture of your daughters guitar as wallpaper
Thank you
Enjoy
Thank you
Enjoy
Give links to your boards.
This is the 2ch board I'll use to drive the mid and tweeter:
TPA3255-2CH-260W | 3e Audio
This is the DSP board:
ADAU1701-2In4Out | 3e Audio
Yes, that's from 3E Audio - the ones I ordered.
Dani,
kindly take note about the ON & OFF POP sounds are there or not also.
Awaiting your review & findings! Thanks in advance
Hi amigos,
Got the new TPA3255 and I will review it later (waiting for my new case) but I can already share some pictures and made an 1 hour test ! sounds Amazing out of the box 🙂 The stock module is fully equiped with Nichicon caps, dead silence no POP when switching ON / OFF, ultra compact size and sounds really better with these minor updates :
For TPA3255 module : Remove 2X Nichicon VZ serie 2200UF/63V > Install 2X Nichicon 4700UF KW serie (low ESR Audio grade)
For LLC SMPS PSU : Remove Output Caps 2X Nichicon PM serie 50V/1800UF > Install 2X Nichicon 2200UF KW serie (Audio grade)
OP amps : Remove NES5532 Op amps > Install Genuine OPA1656 DIP8 socket (mouser)
Will let you know more when the amplifier is going to be fully assembled )
Stock version
A small 110*70*35MM TPA3255 module with :
SAGAMI 7W14A inductors
Full Nichicon caps, as below :
Nichicon 2200UF/63V VZ serie power caps
Nichicon FW serie Buffer caps (Audio Grade)
DIP8 OP amps socket
Hi amigos,
Got the new TPA3255 and I will review it later (waiting for my new case) but I can already share some pictures and made an 1 hour test ! sounds Amazing out of the box 🙂 The stock module is fully equiped with Nichicon caps, dead silence no POP when switching ON / OFF, ultra compact size and sounds really better with these minor updates .....
A small 110*70*35MM TPA3255 module with ....
This amplifier? ; shui yuan Audio TPA3255 2.0 Digital Amplifier Board DC24-48v Strong High Power 300W + 300W Class D o Digital Amplifier Board
Which LLC SMPS PSU ?
I've been testing 3 PSU :
1) 350W LLC PSU (600W peak) 48V / 7.2A with Nichicon KW Audio grade Output caps
2) LLC 300W PSU (600 Peak) 35V / 8.5A with stock caps
3) AudioFX SMPS Brick 36V / 6.5A + 24V/ 6A
Me feeling : best results with Option 1, everything is cleaner, no disturbances, no noise and dead silence between tracks. ( I have some high end floor speakers 93DB / 100W RMS, 2.5 way speakers with Ribbon tweeters). Option 2 works fine too but a I can hear a slight noise when I glue my ears towards the speakers @more than 1m it is almost imperceptible, the same with Option 3.
NB : I will update output caps on Option 2 to check anyway )
The main idea of this project is to get a great TPA3255 with a nice price that fits into a compact 131*249*55mm case )
This type of TPA3255 amp board has a lot of pop noise when the power is turned on and off. Is this new amp board also loud in pop noise?
Dani ... feedback and impression ...
Thank you for all these tests ...
at this price, multi-channel for cheap!
my wife doesn't understand me
which model are you referring to? 😕
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
