US $24.00 20%OFF | shui yuan Audio TPA3255 2.0 Digital Amplifier Board DC24-48v Strong High Power 300W + 300W Class D o Digital Amplifier Board
shui yuan Audio TPA3255 2.0 Digital Amplifier Board DC24 48v Strong High Power 300W + 300W Class D o Digital Amplifier Board|Amplifier| - AliExpress
I already got it... will be my next review with some updates. )
Lol I will let you all know very soon )
Seems to be a very good alternative to the Aiyima A04
Dani,
kindly take note about the ON & OFF POP sounds are there or not also.
Awaiting your review & findings! Thanks in advance
Don't worry ) this is my first criteria )🙂
Active PFFB? Very interesting, saw a forum post a while back on TI suggesting it but with no help on implementation. Had a fiddle around trying to simulate it but couldn't get it stable over full range, would be interested in how you implemented it.FDA TPA325x with active PFFB.
You have link?saw a forum post a while back on TI suggesting it but with no help on implementation
I have successfully applied it in my GaN amplifier, I want to try to use it in 3255 too
Hey, anybody has any experience with the four channel board LINK ?
I want to order it and use it with a 48V power supply. I was looking at the pictures and saw that they used LM7812 (by the mute header) which has max 35V. I am a little confused how this should work.
With 48V that board gets HOT - too hot. I've settled with 36V. There's a switcher in front of the 7812, so no problem there.
Good day…long time reader and first time porter.. ��
I bought a 3E Audio amp + SMPS300RS 48V (adjusted to 46V) as my setup.
I notice there is an light popping sound when turning on/off.
Scenario #1:
Turning on Aiyima T5 preaamp then turning on the 3E audio amp = light popping sound
Scenario #2:
Turnng on 3E audio amp, then turning on Aiyima T5 preamp = light popping sound.
Same case in when turning off.
Is this normal? Or Do I need to add a low voltage soft start switch with relay and will it illuminate the light popping sound?
Thanks a lot in advance…
Scenario #1:
Scenario #2:
L6599.
Совершенно не аудиофильское решение, поставить БП на общую плату с усилителем.
С другой стороны, вход TPA3255 БАЛАНСНЫЙ?
of your choice, balanced or SE
There is no choice. TPA3255 was created directly to the balanced input. Not balanced inclusion, there is an alternative scheme - defective circuitry. The chip itself makes noise at frequencies of about 1 MHz, naturally there will be interference on the input audio signal in the audio range.
Translation:L6599.
Absolutely not an audiophile solution, to put a power supply unit on a common board with an amplifier.
On the other hand, is the TPA3255 input BALANCED?
Thank You.
Обратите внимание, это англоязычный форум.
Translation:
Thank You.
I apologize for switching to Russian. I saw a fellow countryman with an interesting topic.
And what exactly is an audiophile solution, versus a good engineering one and what are the differences? Any facts to back this up?
edit: this was not posted by Allen, only quoted, the original was in the post above.
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
