Mark Audio Alpair 10.3/A10p MLTL
thanks, understand, i need to cut it short then. The radius is 33mm, it should be roughtly 137mm long if i follow the metal cone specification or 114mm long for paper cone specification. Now my existing Port is 150mm. I probably need to cut it shorter to somewhere in between 137-114mm.
Now, the sound is ok but i am still waiting for burn in.
here is the photo. I read some post saying it needs 500 hours run in time. Is it true? Anyway, it's great now.
Markaudio are lousy at updating their site, but FWIW, I've done quite a few more enclosures than are currently there. I'm no Dr Griffin, but in the meantime these might be of interest:
I don't have a design for the Alpair 11ms so you should go with Scott's models if your project is needed now. His design should yield acceptable performance versus any design that I would create.
Good luck on your project.
I'll dig it out. But Dave is quite correct, F3 is borderline meaningless for acoustic purposes (it's basically a holdover from the electrical filter theory T/S values & Small's alignments were based on); it was included 'just because', not because it has any value, and I regretted doing so almost as soon as I put the drawings up.
