Amplifier Modules and PCBs For Sale
  • Thread starter Thread starter Deleted member 148505
  • Start date Start date
I love 230vAC (not DC). It puts the ideas in perspective. 😉
New picture.
What's the thing on the top-right, is that a volume control for later?
A 100K pot. This is a used enclosure box from an old project. I will not use the the pot with the TPA3255 board.
I disabled the PFFB circuit. At first listening, better headroom and natural voice. It's easy to heard as I'm using full range speakers.
It’s weird. The PFFB shouldn't cause such a big difference in sound.
Stéphane
Stéphane
Stéphane: A number of us have noticed this with version 1 of the board. I’ve disabled mine as well and the sound reproduction is much more pleasing. Version 2 of the board is addressing this I believe.
Pete
So you will have the following available within the next 1-2 months (?):
1) TPA3255 module, original (TICore260BTL with new name) but tweaked/improved
2) TPA3255 module, upgraded with split supply
3) TPA3251 module
Or just 2) and 3) moving forward?
Only number 2 is the priority for now. I made some changes on it that I will apply on 1 and 3 afterwards.
The manufacturing cost went more than x2 compared to Version 1. (I used low TCR 0.1% resistor and C0G caps in some areas) So I removed the ENIG surface finish to lower down the cost.
Pete
Sound's like the 2 channels are slightly out of phase that's why the voice is not as full as the non-pffb. I will experiment with it once I receive the new boards.
Tried removing the opamp feedback caps in my TICore260BTL.
Opamps are not heating up (LME49860) so looks stable. Also no faults on open load. I'm using LRS-350-36 PSU which has a 65kHz switching freq.
PFFB: The sound is noticeably better and the vocals are more natural (almost the same as non PFFB)
I'm using ELNA Silmic II all throughout, I soldered them under the board so that I can easily modify the opamp feedback caps.
Maybe a 22pF on opamp buffer feedback cap on my board will suffice for stability.
I need more listening tests to confirm.
