diyAB Amp The "Honey Badger" build thread
Okay, so which is it? I think this merits more discussion.
i am amazed at how quick people are to adopt design practices that was originally meant for one amplifier class as if one size fits all....
for class AB, i would think a voltage regulator would have been better, i have seen it done on some other commercial amps in the past even and it will make better sense...
Joined 2016
Hi Guys, Lets be sure that we are talking about the same thing.
See attached image.
Looking at the schematic, The components inside the red rectangles form a Pi filter. The create a low-pass filter and depending on the component values may attenuate the output in the order of 3 dB at 72 Hz and down 9 dB at the 120 Hz ripple frequency (with respect to the ripple voltage at the first reservoir capacitor). Attenuation is much greater at the higher rectification harmonics.
The total amount of reservoir capacitance is uncritical, but more is usually better. Those networks are there to reduce noise and 60hz Hum. So removing them will increase overall THD and THD+N
For more information on this see.
Power supply filtering confusion
or
PI-filter (or CLC vs CRC vs C)
The components inside the blue rectangles form the input snubbed network to stop the power supply from ringing as the rectifier diodes switch off halting the current flowing in the secondary windings.
Simple, no-math transformer snubber using Quasimodo test-jig
The components inside the green rectangles form the output snubbed network. They are there to damping the output from ringing.
They are probably not necessary but were included on the PSU to make it truly universal.
Joined 2016
Those of you winding your inductors... I read through many threads and watched many videos. If you have a scope and a signal generator, I found this one to be the easiest, for me, to do: How To Measure Inductance - Daycounter
Has the math and a calc if you wish to forgo the algebra. Mine are both at 1.53uH. That was about 15 turns around a 12.4mm core.
Nice... Do you have any photo that you can share.
Sure, I used a cordless drill and a center punch because of the knurling (grips the wire) I chucked the wire and the punch in the drill then ran it for a few turns to get a good grip, then just held the wire spool in my hand and pulled down and back toward the check and spooled it slow. Worked pretty good I think.
