B1 with Korg Triode
avdesignguru
soundhappy
6l6
Papa!
and all of you. This has been a tough year. But this year allowed me to finish myB1 and F6 amps. I am grateful for your genegrousity. I wish that the whole world can respect diverse opionons and learn to accept and agree upon meaningful solutation to our challenges. That's how I was able to finish my projects...team work!
Thanks and have youself a wonderful holiday season
@ Yaho
:xmastree: Thanks for kind words. All glory and thanks again to Mr.Pass and 6L6 for excellent work and efforts on this B1 Korg DIY kit.
:cheerful::xmasman: Happy Holiday Season Merry Christmas :Present: :santa::xmastree::snowman:
Hello, Soundhappy,
So, to make sure I understand, the Uf=804mV reading I got for this 9.1V zener diode by itself isn't a problem. Correct? And if I get 24V in the PSU filtering section then all is well? Do I have this right?
OK, I can see now the 475Rs matter a lot. Thanks for clearing that up. I'll check the weird one again and if it's still way off I'll definitely have to try some others.
Merci
DIY Pass Kong B1 Develops Whistle
Build kit.
Love sound.
But after a period I get a high pitched whistle.
Still there when switch to unconnected input.
Turn off one on. Sometimes goes away. Sometime not.
Does not get louder with volume control.
Help please.
James
james1024:
Same as I got at first, playing for some time then the ( 5k ringing ) start.
First low then more and more, adjusting volume, same db ringing.
Got help from forum, must have a sealed box for it, and it helped me.
Even my box is not 100% sealed yet.
But for some strange reason when I adjusted the B1K to 9.5 v (positive 2N ), no problem. But when reversed the speakercabels to get 2N negative apsolute phase then it rings again. So now I run it at 11.5 v. Maby some vibration hit the nutube as my box is not 100% finish.
Anyway you need a good house for the nutube ( :
Frank
Thanks, Mr. Pass,
Dang, finding a bad Vishay resistor before Nelson Pass found one was this close to going on my resume. (And for the record, I was barely trying.) Such is life, I suppose....
Seriously, though, thanks for your kind offer and your advice.
Thanks as well to 6L6 for his quick response.
