Q factor RLC PSU
Joined 2009
What's the best Q factor for RLC PSU? I read 1/2 = 0.5 = Q critical damped or have I to look for low quality factor (Q < ​1⁄2) is said to be overdamped or high quality factor (Q > ​1⁄2) is said to be underdamped?
If I understood correctly first I have to look for a resonant frequency out of our range of hearing?
TIA
In my opinion it's purely a matter of opinion (!). Different engineers have different preferences and all we can say with definitive certainty is "xxx is the best FOR ME".
Some engineers prefer to optimize in the time domain, and for them, the Bessel choice of Q is preferred.
Other engineers prefer to optimize in the frequency domain, and for them, the Butterworth choice of Q is preferred.
I, myself, prefer to design for the worst case situation in which all components are at the outer edges of their tolerance bands. If the inductor's tolerance is ±15% then I do the calculations with 0.85*Lrated and again with 1.15*Lrated.
If the capacitor's tolerance is ±20% then I do the calculations with 0.80*Crated and again with 1.20*Crated.
If the resistor's tolerance is ±5% then I do the calculations with 0.95*Rrated and again with 1.05*Rrated.
If there are "N" components, I do the calculations (2 raised to the power N) times. So if there are 3 components (R, L, C), I do the calculations (2^3) = 8 times. (2 different inductances) * (2 different capacitances) * (2 different resistances).
I'm not going to say this is BEST approach; rather, it's merely what makes me feel comfortable. Other engineers have other criteria.
Thanks for answer Mark, still a lot of doubts:
-I have to look for a resonant frequency out of our range of hearing for example <20Hz?
-I have to look for Q-factor is smaller than 1/2 = 0.5 then the oscillations quickly die out?
TIA
Well I checked add resistance to the LC PSU before L to lower the Q factor smaller than 1/2 = 0,5 and works.
I guess will be better to increase the capacitance to get a resonant frequency <20Hz will be better, I will try & let you know.
PSUD2 will simulate the differential mode inductance of your choke, which is a key aspect of mains frequency ripple estimation. The ripple and low frequency resonance simulation is only as good as your awareness of part values that influence those issues.
If you aren't confident in the PSUD2 results, because you can't see any oscillation to a step load change, then I'd suggest posting a clip of your simulation front page, and summarise how you determined part values, as posters may be able to see a concern.
Using a CM choke in that location has a few subtle issues, including how rectification noise may bypass the CM choke via any capacitance path from secondary winding to chassis.
Attached PSUDII pic simulation.
What is your transformer? Or did you make the measurements that allowed the secondary winding voltage and effective resistance to be included in the sim?
Are your diodes 1N4007?
What are your cap types (datasheet)?
Does your load have a voltage range, and a current range, for normal operation? Ie. have you constructed the 'load' and made any measurements. If that is not known, then do you have circuitry?
Selectronic R-Core 2x9VAC 30VA
C3D02060F Silicon Carbide Schottky Diode Z-Rec® Rectifier (Full-Pak)
10.000uF Mundorf AG-Lityc
4.700uF Panasonic
2.200uF BG
The load is Amanero USB-I2S so the calculated CCS is a little bit more to proper operation of Salas BiB.
