We recommend you shorten the standoffs by 5mm.
If you were to send those to CeeVee, you could also send him the rear mounting plate.
He'll machine the cutout for you as Morde did in post #102, at no charge.
Patrick
Patrick
Morde DIY (a)
soldersober DIY (a) or better even please post part number for M3-M4 thingy
s610adam DIY (a) - I'm also fine getting the adaptors with all the other fun stuff to order.
markus22ch DIY (a)
Arthur DIY (a)
markus22ch DIY (a)
Arthur DIY (a)
Guys,
I will send all of you the thread adapters for the front so you can screw down your protection PCB.
But come on..we want to see more F5Xs singing...Morde has his singing for ages....
What ?
You refer to the cases ?
...I was talking about Morde's working finished ...singing amp....
That is what we work for ..full finished ..music making beautiful...thingy.
...!! english only please...!! site rules.
i get you others dont.
Thanks...just trying to be fair To EUVLs amazing design effort.
Gentlemen,
I'm tempted to go with c) since I don't have the ability to do much machining work.
But am I correct that sending the standoffs and the mounting plate back for machining
would also be a reasonable solution?
Guys,
Almost there, too busy with this thing called work
Yes.
Patrick
Yes.
Patrick
Gentlemen,
No Problem Dennis, just send them to me and i will fix them and send back to you.
Carlos.
Hi Patrick
any news?
thanks
Markus
Before you order parts, we are testing some new rectifier diodes instead of MSR1560.
So save those first. Will explain when we have results.
Patrick
any news?
thanks
Markus
Waiting for Morde to test. He already has new PCBs for that.
The diodes under test are 3-pin TO220.
It has a lower forward voltage, which reduces dissipation in the regulator heatink.
You should then run the regulator as pure cap multiplier (without the Zener).
The amp will see a fraction of a volt more rail voltage.
So no issue.
If you want to try in parallel, contact Morde for PCBs and details.
Patrick
So no issue.
Patrick
- Group Buys
- GB F5X Amp final build Cases
