UGS-muse preamp GB
PSU Board Substitute
Got the PSU Boards.......
Since it works well with 3 preamps including myself, I am a bit puzzled but suddenly realized that I forgot to mention something important.
Since the SW changes are quite significant, you must load the default settings and better erase all settings.
If you cannot do it with v2.99 use your old working version to do it first (erase all settings).
thx alex. i will try that today in the evening.
you mean erasing all settings in the preamp menu. not in the programmer?
thx for your help
hi alex.
i did not manage to make v2.99 run.
downgraded to v2.93
in manage settings menu i decided "Restore default settings"
then i upgraded again to v2.99 and it didn´t work...
can u please help?
thx
Hi @ fenci 🙂
I had the exact same problem as you have.
Here is the fix (as Alex have mentioned) :
You have to erase all settings.
Just to load the default settings is NOT enough !
YOU HAVE TO ERASE ALL SETTINGS !
Then it will work 🙂
Johnny
