D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based VReg
I made the first tests with LM337 + dienoiser on the diy power supply but then when I tried it on the Magni it just didn't work. I didn't have room to use the same output cap I used in testing.
In the end I did manage to make it work on the Magni as well, just that it was a pain of trial and error. I had to experimentally find the correct values for the comp network. In the end it worked with 40nF + 1R. That 1R seems to be critical. 3.3R/5R/10R wasn't stable. 0.33R seemed to worsen the performance. 0.5R was ok but touchy. I test for oscillations by touching Vout. If it's on the brink that usually gets it off into oscillation. 0.5R worked, it went crazy but would come back. With 1R it seemed to not care when I touch it. I am not sure what R is related to. I did use 4x10nF caps in parallel which would lower the ESR.
Also the output cap is kind of tricky. I tested some and it seems that anything over 40mOhm doesn't work. Most under 40mOhm worked, irrespective of capacitance.
So the LM337 + dienoiser can be made stable just that you really need a LNA to check your results. Osciallation isn't the only issue with it. While tweaking the compensation network + output cap I had it stable in some configurations but the performance was lacking. It would either get the ADC in protection for way too high noise, or it would be sub denoiser performance. To get it to perform as it should it took some time of trial and error. So don't go adding it to a circuit without seeing what's happening. You're safer with the LM337+denoiser. But if you have the tools and are willing to spend the time tweaking it then sure.
Here's the LM337+denoiser and LM337+dienoiser as installed in the Magni, measurement taken at output cap. Some 10dB improvement.
Yes the Magni measurements are pretty clean. The issue is the DAC case+transformer combo. I'm not going to open it again for pictures but here's a photo I found online of the same DAC:
As you can see the transformer core is about 5cm away from the regulators, and the board has a ground plane in the analog output. My probing techniques and equipment are not proper. At those levels it's easy to pickup stuff.
You can tell by the lowered noise floor around those spikes that the denoiser is working. You could have a poorly made pcb layout that picks up some noise that is hidden in the higher noise floor of the rails. Once you clean them it could reveal some issues. All in all the noise is lower anyway.
Also it seems that in this particular DAC the case is not earthed. The earth goes to the transformer's shield but it isn't connected to the case. I need to start looking into case earthing etc
Hi and thanks for all the measurents.
Is it possible for you to try with iron plates in your test setup too separate the noise sources from the electronics.
It could also be a learning task?
Hello Trileru
greetings i want to make this pcb please can you tell
the 2 trs used as i could not open the schematic
warm regards
Andrew
Here's the schematic and layout (C1/C4 are on the backside along with the jumpers):
My LNA and ADC are far from something that could truly characterize the performance of these circuits. They're rather tools that help me see if anything is obviously wrong. It's not worth the time for me improving the testing setup.
edit: the HF noise from that switchmode wall wart was coming through the 230VAC line. I think a power line filter would have helped take that out.
Here's a comparison between LM317 + dienoiser and LT1085 + dienoiser. I tweaked the dienoiser resistor value, seems LT1085 gives better performance at around 1K vs the 560R recommended for LM317. The tests were done on the diy power supply, so the signal of interest is 100Hz and its harmonics. 50Hz is environmental pickup, and you can see it and its harmonics are not attenuated between the regulators. There's around 11.5dB extra attenuation at 100Hz from the LT1085 + dienoiser (orange LM317 and blue LT1085):
edit: 100uF/63V Panasonic FC on the output of LM317 and 100uF/63V Panasonic FR on the output of LT1085
For the denoiser I don't see a problem, but for the dienoiser ideally you'd adjust the dienoiser resistor value for the output voltage. But if you're using it for trimming the voltage close to target then you would be ok without adjusting that resistor as well.
for 78xx, 79xx you can use Technics denoiser:
You will need a very good (and expensive) opamp to match the noise performance of a humble BC337 or even a S9013.
The 1.5K input resistor alone will generate 20 to 30 times the noise of a transistor.
The advantage of an opamp is that the 100Hz gain can be pushed to arbitrarily high levels, to reject the ripple.
Other characteristics will be mediocre.
Elvee,
I remember that Nazar_lv was introduced this circuit as "Capacitorless regulator" but it didn't take too much attention. Probably he was referring to same AC principles as your Denoiser which makes no need for big electrolytic filter capacitors. What do you think?
If I remember correctly, he used this dual rail design on his commercial projects too. Which means it has no stability issues with 2 transistor design on negative rail, right?
S-Audio.Systems // Питание High-end апаратуры без применения электролитов
http://s-audio.systems/public/uploads/PSU/capacitorless-630x547.gif
L78xx/79xx are very good at high frequencies by themselves , they are specd at 100khz. So you only need to improve their lower frequency behavior which is what Technics denoiser does as you mentioned.
The best advantage of an op-amp is that it supports with minimum space on PCB both regulators when using a dual op-amp. I am using MC7805/7905 with zenner ADJ lifter for higher voltages, as mc7805 is the fastest and lowest noise of the series and here you can see two double regulators +-20v, +-10v regulators and you see much higher capacitors than needed...
Elvee,
They are just "Finesse regulators" by Charles Wenzel. They were mentionned at the start of the thread:
D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg.
They work, but they require uncomfortable tradeoffs like impedance vs. noise reduction.
The denoiser not only maintains the key parameters, but it betters them and the DC capabilities of the initial regulator need not be derated.
The 78/79 might be relatively good at HF, but their noise cannot match a BJT, and the very high theoretical PSRR attained by an opamp denoiser is going to be meaningless if it isn't matched by the LF noise from the opamp and its input resistance.
Managed to cascade two LT1085+dienoiser. First one is the +12V rail and the second one is VACC/Vref (in my DAC).
I tried it with LM317+dienoiser for +12V and LT1085+dienoiser for 5V (Vref) but the LM317 didn't like it at all. Then I replaced the LM317 with LT1085. Had to tweak the comp network but got it stable.
Sadly the DAC environment is kinda crap and measurements seem similar to the previous ones. Ideally I'd have to make a better pcb but at the moment I'll use it as it is. Sounds absolutely great!
There was something off about that ams1117+dienoiser for Vref. There was lots of detail but bass was a bit off, kind of lacking. I don't trust those unknown source ams1117.
Since I'm almost done with the dienoiser mods in my gear I figured I might test the nonoiser as well. I made a simple tht version that is also diy-able. It's 27mm X 21mm. The inductor is actually the ferrite bead, I didn't have a 3D model for it. You could bypass with a wire and install the bead on the bjt's leg. I attached the Kicad project with pdf for diy and gerbers for fab.
Elvee, if it isn't stable what could be tweaked? I had C/Rcomp for the dienoiser.
This design has not been tested, you make it at your own risk.
I made a comparison between the dienoiser that is onboard the DIY supply I made, from post #1396 and the add-on dienoiser from post #1590 that I attached to the DIY supply, after removing the onboard 220uF from the ADJ pin. I wanted to see if there's a significant difference of performance between the one that is onboard and the dangling add-on. The result at 12V and 80mA is that they both behaved almost identically. The add-on had around 4-5cm of wire between.
