Hello Mile
greetings does this amplifier need zoebel output inductor
warm regards
Andrew🙂
No need inductor, but there is mistakes on your board...
So I have been reading over this post for about 2 hours. I'm looking for boards to build the HV23 but not really finding those. Do they exist or is it possible to get gerbers and place order.
thats quick Andrew, . meanwhile i made another version. but the one you already made is best.
just remember to use metal film / carbon film for the zobel Resistor, as wirewounds can cause oscillation . just something i learnt recently on Mooly's mosfet amp thread.
regards
prasi
regards
prasi
regards
prasi
Hi Jacques,
Here are the pdf and gerbers. These are diy designs kindly provided by APEX, so no issues in posting.
regards
prasi
Hi Jacques,
regards
prasi
Thanks Prasi.
I just completed the 'doctoring' of your purple image with Photoshop to generate a laser-printable BW image 😀😀😀!
Jacques
Mosfet Amplifier
Hello
greetings and many thanks to Mile and Prasi amplifier came on first
time very detailed musical sound .
warm regards
Andrew🙂🙂
Hello
warm regards
Andrew🙂🙂
Looking good Andrew, Prasi is indeed very good with his layouts.🙂
What rail voltage are you using ?
i am using +/- 30 v0lts DC
Hi Andrew,
Congratulations for your build!
Did you change any resistor value from the schematics for running at 30V instead of 55V ?
Jacques
So just asking again are there boards for the HV23 version with 4-5 transistors per side available. Or possibly gerbers?
- MOSFET Amplifier IRFP240/IRFP9240
