Unusual amp from 1987
I'll check it out and throw it in the sprint.Meanwhile, the drawing.
With overload protection
I have a symmetrical version of the PCB . Sketch. I can share
Thank you Maxim. First I want to build the low power version of quasi hexfet and if it really sounds as clear as Korvet amps i will try the higher power version as well. On a Russian site I found a great version of the "УМЗЧ" amplifier with impressive sound and specifications:
- THD at 20 kHz: 0.001% (150 W/8 Ohms)
- Bandwith (-3 dB): 0 - 800000 Hz
- Slew Rate: 100 V/μs
- S/N: 120 dB
What we want more? Unfortunately this project seems a bit complicated for me.
Joined 2014
capacitanc7 should be increased. 22PF
It is necessary to select it.
C12/c13 can also be increased
( It looks much better with 100 Ohms (In original Wiederhold it is 1k)]750ом УМЗЧ ВВ и СЛА
Maxim, which exactly capacitors in which schematic did you mean?
There is still a slight problem with clipping behavior at 1.7V.
I don't think it's really critical, but maybe it can be solved somehow?
It was about LP / Lomakin/The Parshin. C7/C12/С13
This is correction in the ancient Wiederhold /
Я не думаю, что это действительно критично
Not critical. It doesn't affect your work
