v12 car amp protect mode
my v12 car amp on protect mode
but when it warms up a few mins.
i turn it off and on it will.work good
i removed input and output wires just to check shorts
no good still.in protect mode
found out that i need to turn it on let it sit for few mins on protect mode
after that i turn it off then on it will.work fine.
but if its not used for.hours/days when i power it on stil on protect mode
i just do warm it up.to make it work
is this a soft start issue? caps inside the amp not charging??
picture inside
while im getting voltage on tl494
on protect.
checkingbon pin16. amp turn out of protect mode and dont go to protect by now.. i try to cool it down again then i will get al voltage on tl494
pin1 0.0
pin2 4.9
pin3 0.07
pin4 4.3
pin5 1.5
pin5 3.42
pin7 0
pin8 15.11
pin9 0
pin10 0
pin11 15.10
pin12 15.20
pin13 4.9
pin14
pin15
pin16
This looks like it's counterfeit if it says Alpine on it.
Pin 4 is being driven high.
Post a good quality photo (in focus, no flare from the flash...) of the area shown below. Have that area fill the entire frame. Straighten C511 and any other components that block the view.
