Photo Gallery
Câlisse.
One of the cheap Chinese KT88 seems to have snuffed it. It was only 110c when the others were 180c...
Now there is a lonely 6550 in it's place.
It works though so J'men câlisse!
Is there caps on output?
Thanks @azazello ! 🙂
That said, due to extreme compacity (275 x 175 x 65mm for one chassis), there's a 3-speed fan cooling at the back, using a chimney effect around the 6080 :
Fortunately, the 1st speed is enough to maintain the chassis cold and limit the heat around the 6080 at a reasonable value... 😎
The power output is 10WRMS on 16R, the onset of clipping being at 13-14WRMS. The bandwith is less than 1Hz to 250KHz. THD is circa 1.5 to 2% H2 at 10W.
A+!
Very nice amp congrats, I have a question, what would be the outcome of a failure on one tube to the speaker ? ...all the best
Thanks @kissabout2002 !🙂
Nearly nothing on a true OTL SEPP circuit - and by the way nothing dangerous for a speaker : at worse of the worse, 0.5 to 1VDC offset voltage, that can be easily identified. Remember that 1WRMS on 8R represents 2.83V...
A+!
