Thanks for the guidance Doc.Resistor 3-10k
No need film caps, need MLCC
Any brand/value for MLCCs?
any thumb rule for calculation?
if I use 22000uf x4 will it be overkill? any negative effect?
SLPX223M050H9P3 | Cornell-Dubilier 22000μF Electrolytic Capacitor 50V dc, Through Hole - SLPX223M050H9P3 | RS Components
FYI My SMPS is below link, customized for Single 42V.
GHXAMP HIFI Switch Power Supply Dual DC 24V 48V 60V 80V 300 500W Power Supply Board With Heat Sink For Low power Amplifier 1pc|Amplifier| - AliExpress
Any, 100V 1-10ufAny brand/value for MLCCs?
No need add caps for SMPS.if I use 22000uf x4 will it be overkill? any negative effect?
Ok Doc. thanks for the clarification.
If I add caps, will it have any negative effect?
Depends on the power supply... too much capacitance can impact the OCP or startup of the SMPS, causing a "hiccup" where the supply will try to start, charge the added caps, then go into OCP, and get stuck in a cycle of perpetually trying to start up.
Also, an SMPS does not work the way a traditional linear supply does. They generally use feedback for regulation, so they don't need massive banks of caps to maintain good regulation. Adding capacitance to a typical SMPS it likely to cause more problems than it will solve.
Owen
Need to listen)
Depends on the power supply... Adding capacitance to a typical SMPS it likely to cause more problems than it will solve.
Thanks Doc & Owen. Anyway I already ordered the pcb.
once I receive the pcb, will check the lead spacing, order the caps (22k uf x 1 first and check)
is this 22000 uf model ok?
at output it has only one 1800uf 50V
Doc,
I am about to buy the PCB for capacitor bank for tpa3255 amp, in below link
HP7 Main filter power supply PCB|pcb|pcb powerpcb power supply - AliExpress
what are the resistor and axial legged capacitor for?
same pcb with capacitors assembled, sold by same seller.
Are you building a rectifier?
What are you building?
Not rectifier bro, just capacitor bank after SMPS before connecting to amp board. that pcb has no place for diode.
thanks
+1 to what Owen said.
I would be very careful following a smps with lots of capacitance.
Noted bro thanks, I already decided against it based on Doc & Owen feedback.
Folks, I started this last round of discussions back a few days ago. And based on your appreciated feed back, I decided to purchase an AIYIMA A07. There was a recommendation that I look for a 600w 48v power supply. I found this on Amazon for $29 USA, sold by EYEboot.
https://www.amazon.com/gp/product/B07VRQHHS2/ref=ox_sc_act_title_2?smid=A1TSKG9WMIX8W&psc=1
It's a smaller version of ASIC MINER model AM-600-48. Specs sheet below. Price seem very good. Why won't this work?
Just a moment...
Just a moment...
Thanks Dr. so now i wait for my stuff to arrive. More then likely I will want to swap Opamps. Seems that is what others are doing. I’m researching now, but there appears to be a lot of options. My goal is a larger sound stage, any suggestion out there where I can start?
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
