AB100 Class AB Power Amplifier
As far as filling in the missing numbers labelled as stash, ill do it. Working on BOM now. Trying to match my first AB100 amp as close as possible. And no I don't know what I did with that BOM. Anyway working on running two in bridged mode on some older Maggies. Planning on using balanced out from Self preamp.
In have one that I already finished about 6 months back. i listened to it off and on for about 2 weeks. I also have a HB amp also. Right now the HB is a better match for my speaker setup. I'm using very power hungry speakers Maggie IIc's. The AB is just a little under powered when i start turning up the sound. Therefore I'm looking at building another to match the first and using each as a monoblock. Not sure if that will be a problem because of the 6ohm load of the speaker. Each AB will see 3ohm load?? Not sure how it will handle that??
Joined 2018
DaveFred, it can't be a consensus without YOUR opinion.
  • 1.6mm or 2mm board with 1oz or 2oz copper?
  • Finish should be Enig?
I am just a clueless noob who wants to build a Nelson Pass amp.
The Tim Allen in me says bigger is always better, so 2mm thick and 2oz copper, but it costs more.
I don't know if more is better in this case and if it is worth the extra expense, or even if it has drawbacks (capacitance?).
From the little bit I have read about surface finished, ENIG should be the way to go.
Thinking about ordering some boards from JLCPCB from Papa's gerbers. They would be 2.0mm thick, red mask, 2oz copper, ENIG.
Ordering 20 boards from JLCPCB. That's for 2mm FR4, 2oz copper & ENIG finish.
And there was something I knew I want: 2mm PCB thickness, 2oz copper thickness, interesting or base green solder mask color and ENIG surface finish.
So I decided it would be 2.0mm thick FR4 (TG 13-140) boards.
Purple solder mask.
ENIG (2U") finish.
2oz copper.
There you have it, what I was going to go with based on a sample size of three.
I was looking to see if there were any dissenters or alternate opinions and weigh them against what I have read, before I ordered some boards.
David.
Joined 2018
If I've calculated correctly it clips at about 120watts a side with 49V rails. I was expecting the good bass as others have said but I'm pleasantly surprised at the airy highs and imaging. A very listenable amplifier. Many thanks to Nelson for the circuit and to jwjarch for the boards.
Can you post more pictures of your finished amp?
What are some of the build details, like power supply specs, etc?
Thank you,
David.
Joined 2006
Hi DaveFred,
The build is mostly as per NP's schematic. I used what I had around mostly. I didn't have 10,000 mF caps that fit on the amp board so I made a couple perf boards where the channels share the first 30,000uF on each rail then I put 2 x 6800uF per rail on the boards. The transformer is 500va with dual 35V secondaries. The common filter goes CRCRC with 10,000 - 0.25 Ohm -10,000 - 0.25 Ohm - 10,000. Like I said, I had these caps so I used them, I'm not saying they are needed or even helped.
Joined 2018
I think this is the AB100,
Portal Audio Panache Integrated Amplifier
To me it looks like there was no "separate" capacitor bank, just the ones on the amp boards, fed by a dual output 425 VA toroidal transformer to two bridge rectifiers.
Original text,
Why A Passive Preamp/High Gain Amp?
When we began to tackle the idea of a world-class, budget-priced integrated amp, the first ugly reality we faced was that you can't build an excellent-sounding active line stage on the cheap. Our answer was to build a passive line stage using the same level of parts you'll find in very high end preamps.
Although passive preamps are theoretically the most pure, many good free-standing designs just don't sound that good when connected to solid state amps. Most of them sound lifeless and lacking in dynamics. Reality is that the very high output impedance of the passive unit is being asked to drive the (generally) low input impedance of a solid state amp. Making the situation worse, is that the signal has to travel from preamp to amp over a length of reactive interconnect cable.
BUT...
What if you connected the output of this preamp directly to the input of a high-gain solid state amp designed expressly to receive that specific signal? That's the guiding design principle of the Portal Panache.
We're not claiming that the preamp section of this unit is perfect. It's just more perfect functionally than anything remotely in its price class. The input selector, balance control, and attenuator are Alps controls, each hand-selected for neutrality, lack of noise, and reliability. All point-to-point wiring - 14 gauge OFC with PE dielectric - is the shortest possible path. In other words, the signal only goes through the Alps controls and scant inches of pure copper before being delivered intact to the input of the amp.
Dual Mono Amplifier Section
The amplifier section is a dual mono design. The toroidal transformer, custom built for us in California, has separate windings and separate rectifier bridges for each channel. After the transformer, the two channels are completely separate, each with its own bank (40,000 MFD/ch) of filter capacitors, and each channel physically isolated to prevent interaction with its twin.
The transformer itself is rated at 425 va and is capable of producing twice its rated power for extended periods. With a potential 400 watts of power dissipation per channel - 4 pairs of high-speed bipolar output devices rated at 100 watts/12 amps per device - the rated 100 watts per channel into 8 ohms is very conservative. Operation is A/AB, with all stages before the output transistors operating in single-ended Class A mode.
MADE IN THE USA
To order call 1-888-737- HIFI
Description and Specifications
Click to Enlarge
The amp design is a classic complimentary symmetry A/AB design with a current source differential pair followed by a common emitter going to a Darlington configuration output stage.
Specifications:
Rated output: 100 watts/ch at 8 ohms;
200 watts/ch at 4 ohms
Click To EnlargeDistortion: 20 Hz-20kHz both ch driven
@ no more than 0.1% THD
Bandwidth:5 Hz to 100 kHz
Gain: 20 dB
Input impedance: 22 k Ohm
Slew rate: >20 v per microsecond
Specifications are subject to change without notice.
Joined 2018
Joined 2018
So was looking for some feedback in earlier post on bridging output and using with a 6 ohm load?? Too much for this amp? Notice that it is rated for double output into 4 ohms so that is a good sign.
In the amp you built, what did your power supply chain look like?
Did you just have the transformer into a rectifier onto the board?
Any Pics?
Thank you,
David.
