RJM Audio Sapphire Desktop Headphone Amplifier
The schematic on your webpage shows an output stage with multiple To-92 devices whereas the PCB shows single bd139 or similar in the output stage.
I believe one of them is wrong or at least another version.
What are these versions called/referred to?
Thanks!
Probably not, and I only have the 4.1z and 4.2b boards myself.
As you note, though, there are Gerber/.brd files floating around so you can get older versions made if you prefer.
Having listened to all the revision history, the "4" (all discrete) is superior to all previous versions of the Sapphire using op amp input stage.
-Richard
Thanks Richard.
I´ll take my time to think about what I need.
I´d love to do a tiny SMD-version but don´t understand hfe-variations enough to proceed with it.
If I take the simulation file that was attached earlier (sapphire_41m_thd.asc),
the BC327-25-model has a hfe of 385.7 and the BC337-25-model of 292.4.
Simulation of DC-offset looks fine. Even with a hfe-variation of +-5.
But let that variation get bigger or change the absolute values of the models and DC-offset quickly can become >100mV.
See attachment with "original" hfe-values with variation of +-20.
If I make the hfe of npn and pnp the same it still doesn´t work out to 0V offset.
Probably need some time to digest that.
..for those, who do.
  • sapphire-42b.zip
    sapphire-42b.zip
I would like some considerations if possible.
1- Could anyone say how this amp performs with HE400i sound stage, bass etc?
2- How does this amp compare to the L30 or A50 topping etc?
3- This project seems similar to the Little Dot MK V amp does anyone know which one is better?
Hello.
Could someone help?
I'm looking to mount this Sapphire amp, but I need to know if it is possible to make a small change to the final assembly.
I have a hearing impairment heard on the right side hears less than the left, so I think of mounting the sapphire with two audio outputs and two volume controls so that I can adjust the sound on each side of the phone so that there is no imbalance in the ear canal.
Would it be possible and how would you do it?
Thanks.
