Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Hi Everyone,
After enjoying the standard stack for quite a while now, I built a 2nd one over the weekend, plan on hooking up a TDA1541A DAC to it.
Looking for suggestions for the RPi 4 OS Image to use.
Not having luck with Max2Play or Volumio.
Thanks in advance,
Aguaazul
1. UMarcus 1A*1, 3A*1, 4A*1, 6A*1, 7A*1, 8A*1, 9A*1, 11A*3, 12A*4, 13A*1, 16A*2, 21A*1, 22A*1, 23A*2, 24A*1, Update : 10A*2, 27*1
2. AlanElsdon 19A*1, 21A*2, 22A*1, 23A*2
3. Maniolo 1A*1, 9A*1, 12A*3, 20A*1
4. Arnolddew 1A*1, 9A*1, 13A*1, 20A*1, 23A*1
5. AudioDAC 16A*1, 19A*1, 20A*1, 23A*2, 24A*1,
6. Narukas 9A*1, 11A*4, 19A*1, 23A*2, 13*4, 23*1
7. kft 1A*1, 3A*1, 4A*1, 6A*1, 8A*1, 9A*1, 16A*, 24A*1, 27*1
8. Patjr 8A*1, 19A*1, 21A*1,23A*2
9. Sam402 1A*1, 11A*4, 12A*3, 18A*1, 20A*1, 23A*1
10. duanbui 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1
11. ffeg2008 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax1, 8Ax1, 10Ax1, 13Ax2, 14Ax2, 19Ax1, 23Ax2, 24Ax1,27x1
12. Bartb 30A*1, 28A*2, 25A*2
13. vanofmonks 19A*1, 21A*1, 23A*1, 27*1
14. samsie 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax2, 8Ax1, 13Ax4, 14Ax2, 20Ax1, 23Ax2, 24Ax1,27x1
15. Boldname 1*1, 2*1
16. Narukas 11*2
17. atiq19 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 9A*1, 10A*1, 12A*1, 13A*1, 21A*1, 23A*2, 24A*1, 9*1, 11*2, 12*3, 16*4, 20*1, 22*16
18. ittien 9x1
19. roubo 1A*1 9A*1 11A*2 12A*3 13A*3 20A*1 21*4
20. druidaudio 1A*1, 20A*1, 22A*1
21. roubo 2A*1 3A*1 4A*1 6A*1 8A*1 10A*1 13A*1 16A*2 19A*1 21A*1 23A*2 24Ax1 21*2 22*10
22. klweds 1A*1
23. VT67 1A*1, 12A*1, 20A*1, 23A*1, 24A*1, 27*1
24. luchoh 1A*1, 9A*1, 11A*4, 13A*4, 20A*1, 13*4, 17*8, 20*2
25. kirks 12A*2, 27A*1
26. Domg 12A*1, 22A*1, 23A*1, 27A*1, 28A*2, 29A*1
27. Joseacm08 21A-SMD*1, 28A*4, 30A*1
28. mksung 25A*2, 26A*1
29. Victhor34 1A*1, 20A*1
30. Heathkit 1A*1
31. sfleming 9A*2
32. clsidxxl 25A*2,26A*2,2A*2
33. bug2k11 19A*1
34. Raimundas 25A*1, 26A*1
35. Cerole 29A * 1 , 27A * 1 , 28A * 3 , 25A * 1
36. metronet 4A*1, 25A*1, 26A*1, 30A*1, 31A*2, 32A*1
37. NicMac 25A*1, 30A*1, 31A*1
38. stew1234 1A*1, 19A*1, 22A*1, 25A*2, 26A*1, 30A*1, 27*1
39. Aguaazul 4A*1, 23A*2, 27A*1, 28A*4, 29A*2, 30A*1
40. A123 1A (Q3)*1, 20A*1, 21A*2, 23A*2
41. _oxygen 1A (Q3)*1, 4A*1, 23A*2, 32A*1, 33A*1
42. minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
43. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
44. erikovsky 31A*1, 1A*1
45. JimS 25A*1, 26A*1, 30A*1
46. Studley. 25A*2
47. SimonJ 1A*1, 2A*1, 14A*2, 24A*1, 27A*1, 28A*2, 29A*1, 30A*1, 27*1,
48. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
49. wealas 30A*1
50. linh0983 1A*1, 25A*1, 32A*1
51. Subbu K 25A*1, 26A*1, 30A*1
52. Karahana 3A*1, 4A*1, 6A*1
53. Patjr 27A*1 28A*4 29A*1
54. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
55. Jack0k 1A*1, 20A*1
56. marcus1 1A*1, 9A*1, 11A*2, 12A*1, 19A*1, 20A*1, 23A*2
57. Photochum1 25A*1, 31A*1, 23A*1, 13*3
58. AirAir 1A(Q3)*1, 20A*1
59. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
61. nounouchet 19A*1, 20A*1, 26A*4
62. wcwc 1*1, 2*1, 13*22, 19*1
63. cec 1A*4, 9A*3, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 34A*2, 13*12, 22*3
64. twitchie 1A*1, 10A*2, 13A*2, 16A*4, 19A*1, 20A*1, 23A*2, 24A*1
65. mnichols30030 25A*1, 27A*1, 33A*1, 34A*1
66. 18gb 1A*1, 3A*1, 17A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
40. A123 1A (Q3)*1, 19A*1, 20A*1, 23A*2
46. Studley. 25A*2
49. wealas 30A*1
FifoPi Q3
FifoPi Q3 new improvements
· Supports oscillators (XO) with and without OE pin
· Uses pure 3.3V for a clean side DC power supply. All LDOs have been removed to allow direct operation with a better 3.3V power solution via LifePO4 or ultra capacitor.
· Optional u.fl input sockets for connection to external oscillators via coaxial cables.
· Supports single XO mode.
· Customized SMT XO sockets for easy replacement.
· Isolated MUTE and DSD EN outputs for better operation with pure DSD DACs or external PCM/DSD DACs (via TransportPi or HdmiPi).
· New high-speed 300MHz flip-flops to reduce the additional jitter of the final I2S/DSD reclocking.
· Optimized decoupling networks to improve power supply performance.
FifoPiQ3_2 by Ian, on Flickr
Hi guys , I have an Allo usbsig with FIFOPI Q1 and the spdif output board. i want to upgrade to a FFIFOPI Q3 but the system is powered by an Allo Shanti which only has the two 5v outputs. Ny first thought was to buy one of Ian's new 3.3v powersupplies and the conditioner but the cost starts to add up quickly. My second thought was to use a high quality regulator eg Dexxa at the power input on the Q3 board. Given that I have the Shanti already will the second solution be close in performance to the first. Thanks in advance,Gordon
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
67. Morde 1A*1, 12A*1
UPDATE cec @ row #63
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
63. cec 1A(Q3)*4, 9A*3, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 34A*2, 13*12, 22*3
Sorry, just noticed my current HAT has no 40-pins. Already terminated. Removing a GPIO terminator @#40.
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
40. A123 1A (Q3)*1, 20A*1, 21A*1, 23A*2
46. Studley. 25A*2
49. wealas 30A*1
update of "old PIfifo to latest version" ?
https://flic.kr/p/2jH3qv2
Hi IanCanada.
I would really have an PIfifo with latest updates for best Sound performance.
Is it possible to buy an "update kit with components and instruction" for updating the first PIfifo to the latest version (Ver3) ? I know it is not easy to replace SMD componets but without the right tool. but i have the right solder tool for replace of SMD components. (hotair and heat under the PCB).
Br
Caad.
Updated order 36.
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
36. metronet 25A*2, 30A*1, 31A*1
46. Studley. 25A*2
49. wealas 30A*1
Ian, I saw Fifopi 3 is available and I just realized it is 3.3V. I have 2 Acopian regulated linear power supplies and both are 5V output. Can the Fifopi 3 be modified to use 5V? Can you also send me the link of your battery with 3.3V, I’ll look into it and will decide.
Thank you
Ian, Scratch off my last post. I did a little reading and it makes sense to get LiFePo4 batteries for it. Does Fifopi 3 have microUSB port for powering or powering through GPIO. I’ll take the Fifopi 3 and the transport. If I add the dual mono ESS9038M2Q DAC HAT, do I need a separate power supply for it or I can use Lifepo4 battery for Fifopi 3 + transport + DAC HAT. RP3B+ will get its separate power. Please let me know.
Thank you
Hi Ian
I am building my first DAC. Since it’s my first try I have purchased used what looks like your original fifo along with a dual clock board (with crystek) and the spdif interface board.
I am trying to finalize a simple 6V power supply for all three of these boards based on a Salas SSLV and want to make sure I have a sufficient current setting without creating excess heat.
I have read through the board manuals and only found one reference in the fifo manual stating that a 6V 500mA supply is needed.
I’ve spent many hours reading other posts in this and other threads that contradict the 500mA statement. This is especially true it seems if not all the same boards are used or different crystals are installed on the dual xo board.
I know I’m very late to this game and everyone has moved along light years to your many newer products.
Could you please tell me what your recommended current setting would be for the SSLV to power the boards as I am using them?
I’ve attached a picture for reference.
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
46. Studley. 25A*2
49. wealas 30A*1
68. bb870817 30A*1
