Ian asynchronous I2S and S/PDIF FIFO KIT group buy
UPDATE #62
1. UMarcus 1A*1, 3A*1, 4A*1, 6A*1, 7A*1, 8A*1, 9A*1, 11A*3, 12A*4, 13A*1, 16A*2, 21A*1, 22A*1, 23A*2, 24A*1, Update : 10A*2, 27*1
2. AlanElsdon 19A*1, 21A*2, 22A*1, 23A*2
3. Maniolo 1A*1, 9A*1, 12A*3, 20A*1
4. Arnolddew 1A*1, 9A*1, 13A*1, 20A*1, 23A*1
5. AudioDAC 16A*1, 19A*1, 20A*1, 23A*2, 24A*1,
6. Narukas 9A*1, 11A*4, 19A*1, 23A*2, 13*4, 23*1
7. kft 1A*1, 3A*1, 4A*1, 6A*1, 8A*1, 9A*1, 16A*, 24A*1, 27*1
8. Patjr 8A*1, 19A*1, 21A*1,23A*2
9. Sam402 1A*1, 11A*4, 12A*3, 18A*1, 20A*1, 23A*1
10. duanbui 1A*1, 9A*1, 11A*4, 13A*3, 14A*1, 20A*1, 21A*1, 22A*1, 23A*2, 27*1
11. ffeg2008 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax1, 8Ax1, 10Ax1, 13Ax2, 14Ax2, 19Ax1, 23Ax2, 24Ax1,27x1
12. Bartb 30A*1, 28A*2, 25A*2
13. vanofmonks 19A*1, 21A*1, 23A*1, 27*1
14. samsie 1Ax1, 3Ax1, 4Ax1, 6Ax1, 7Ax2, 8Ax1, 13Ax4, 14Ax2, 20Ax1, 23Ax2, 24Ax1,27x1
15. Boldname 1*1, 2*1
16. Narukas 11*2
17. atiq19 1A*1, 3A*1, 4A*1, 7A*1, 8A*1, 9A*1, 10A*1, 12A*1, 13A*1, 21A*1, 23A*2, 24A*1, 9*1, 11*2, 12*3, 16*4, 20*1, 22*16
18. ittien 9x1
19. roubo 1A*1 9A*1 11A*2 12A*3 13A*3 20A*1 21*4
20. druidaudio 1A*1, 20A*1, 22A*1
21. roubo 2A*1 3A*1 4A*1 6A*1 8A*1 10A*1 13A*1 16A*2 19A*1 21A*1 23A*2 24Ax1 21*2 22*10
22. klweds 1A*1
23. VT67 1A*1, 12A*1, 20A*1, 23A*1, 24A*1, 27*1
24. luchoh 1A*1, 9A*1, 11A*4, 13A*4, 20A*1, 13*4, 17*8, 20*2
25. kirks 12A*2, 27A*1
26. Domg 12A*1, 22A*1, 23A*1, 27A*1, 28A*2, 29A*1
27. Joseacm08 21A-SMD*1, 28A*4, 30A*1
28. mksung 25A*2, 26A*1
29. Victhor34 1A*1, 20A*1
30. Heathkit 1A*1
31. sfleming 9A*2
32. clsidxxl 25A*2,26A*2,2A*2
33. bug2k11 19A*1
34. Raimundas 25A*1, 26A*1
35. Cerole 29A * 1 , 27A * 1 , 28A * 3 , 25A * 1
36. metronet 4A*1, 25A*1, 26A*1, 30A*1, 31A*2, 32A*1
37. NicMac 25A*1, 30A*1, 31A*1
38. szczemirek #25A*1, #30A*1, #33A*1, #1A*1
39. stew1234 1A*1, 19A*1, 22A*1, 25A*2, 26A*1, 30A*1, 27*1
40. Aguaazul 4A*1, 23A*2, 27A*1, 28A*4, 29A*2, 30A*1
41. A123 1A (Q3)*1, 20A*1, 23A*2
42. _oxygen 1A (Q3)*1, 3A*1, 4A*1, 23A*2, 31A*2, 32A*1
43 minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
44. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
45. erikovsky 31A*1, 1A*1
46. JimS 25A*1, 26A*1, 30A*1
47. Studley. 25A*2
48. SimonJ 1A*1, 2A*1, 14A*2, 24A*1, 27A*1, 28A*2, 29A*1, 30A*1, 27*1,
49. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
50. wealas 30A*1
51. linh0983 1A*1, 25A*1, 32A*1
52. Subbu K 25A*1, 26A*1, 30A*1
53. Karahana 3A*1, 4A*1, 6A*1
54. Patjr 27A*1 28A*4 29A*1
55. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
56. Jack0k 1A*1, 20A*1
57. marcus1 1A*1, 9A*1, 11A*2, 12A*1, 19A*1, 20A*1, 23A*2
58. Photochum1 25A*1, 31A*1, 23A*1, 13*3
59. AirAir 1A(Q3)*1, 20A*1
60. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
61. wcwc 1*1, 2*1, 13*22, 19*1
62. cec 1A*3, 9A*3, 11A*8, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 22*3
Joined 2004
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
63. twitchie 1A*1, 10A*2, 13A*2, 16A*4, 19A*1, 20A*1, 23A*2, 24A*1
UPDATE #42
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
42. _oxygen 1A (Q3)*1, 4A*1, 23A*2, 32A*1, 33A*1
47. Studley. 25A*2
50. wealas 30A*1
Report Post Reply With Quote Multi-Quote This Message
Unread Yesterday, 05:40 AM #4102
twitchie is online now twitchie Canada
Magic Smoke Liberator
diyAudio Member
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
Sorry, Update #42 again
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
There are a lot of upgrades you can do:
I would change the raspberry pi for a usbridge signature from Allo to start.
You can use a better power supply for your rpi (or usbridge sig.) like the conditionerpi or UcConditioner.
You can buy a fifopi
You can upgrade the clocks of the fifopi for accusilicon or crystek clocks or even the ultimate Well tempered clock modules from Andrea Mori.
It all depend on how much money you want to spend.
Regards,
Disabled Account
Joined 2020
@JCMcNeil was kind enough to post this link to help me get started / caught up:
For translation in your language, just check the translate option on the upper left of this page Na de succesvolle avonturen met de Allo Kali Reclocker in - BerryStreamer met Ian Canada FiFoPi
I noticed a cross correlation of the products you mentioned have similarities to products via the link.
I have to work within constraints. Small footprint as possible. LiFePO4 Single Battery powered FiFoPiQ3 transport. So I have to go Accusilicons at this time for this project. I'm new to all of this so it's a good start to get feet wet.
Otherwise, I would do everything possible to try to make Andrea Mori clocks work. I see it as saving money in the long run by bypassing the Accusilicons/Crysteks. It's something I look forward to down the line. I'm not into incremental upgrades as that cost more in the long run than just getting the ultimate the first time around.
If reasonable cost, you may only have a few weeks to get in on the current GB. I'm new so don't know, but it seems like with the Q3 release it may only be a matter of time before the Summer 2020 GB ends.
Thanks guys for the replies, much to think about. I will read up on the USbridge as I'm not too sure how it all fits in but I'm sure its an upgrade ove the Pi.
I assume it can be built in as another board to the DDDAC case I'm using making it all in one unit whch would be neat.
Another Question:
Do I still need to use the Kali between the UsBridge and the DAC?
Yes, kali is still recommended because the usbridge does generate the audio clock signal in the same way as the rpi and this is a high jitter clock signal.
The advantage of the usbridge is that the powerlines use all lineair regulators instead of noisy smps; result less noise. The board generates also less rfi.
Disabled Account
Joined 2020
Update where ID = "41"
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
41. A123 1A (Q3)*1, 20A*1, 21A*2, 23A*2
47. Studley. 25A*2
50. wealas 30A*1
A123 erased my line (post #4089) in its #4095!
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
61. nounouchet 26A*4
62. wcwc 1*1, 2*1, 13*22, 19*1
63. cec 1A*3, 9A*3, 11A*8, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 22*3
64. twitchie 1A*1, 10A*2, 13A*2, 16A*4, 19A*1, 20A*1, 23A*2, 24A*1
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
65. mnichols30030 25A*1, 27A*1, 33A*1, 34A*1
== UPDATE cec @ row 63 ==
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
63. cec 1A*3, 9A*3, 11A*8, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 34A*2, 22*3
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
61. nounouchet 19A*1, 20A*1, 26A*4
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
47. Studley. 25A*2
50. wealas 30A*1
63. cec 1A*4, 9A*3, 12A*9, 20A*3, 22A*1, 23A*2, 25A*1, 26A*1, 32A*1, 34A*2, 13*12, 22*3
16. Narukas 11*2
18. ittien 9x1
22. klweds 1A*1
30. Heathkit 1A*1
31. sfleming 9A*2
33. bug2k11 19A*1
38. stew1234 1A*1, 19A*1, 22A*1, 25A*2, 26A*1, 30A*1, 27*1
39. Aguaazul 4A*1, 23A*2, 27A*1, 28A*4, 29A*2, 30A*1
40. A123 1A (Q3)*1, 20A*1, 21A*2, 23A*2
41. _oxygen 1A (Q3)*1, 4A*1, 23A*2, 32A*1, 33A*1
42. minivan 13a*1, 24a*1,23a*2, 22a*1,21a*3
43. nielsek 3A*1, 8A*1, 27A*1, 28A*2, 31A*1
44. erikovsky 31A*1, 1A*1
45. JimS 25A*1, 26A*1, 30A*1
46. Studley. 25A*2
47. SimonJ 1A*1, 2A*1, 14A*2, 24A*1, 27A*1, 28A*2, 29A*1, 30A*1, 27*1,
48. Lindamar 1A*1, 2A*1, 3A*1, 4A*1, 9A*1, 11A*4, 12A*2, 13A*1, 14A*1, 19A*2, 21A*1, 23A*1, 25A *1, 26A*1, 27A*1, 28A*1, 29A*1, 31A*2, 32A*1, 4*1
49. wealas 30A*1
50. linh0983 1A*1, 25A*1, 32A*1
51. Subbu K 25A*1, 26A*1, 30A*1
52. Karahana 3A*1, 4A*1, 6A*1
53. Patjr 27A*1 28A*4 29A*1
54. delfimmarues 1A*1, 9A*1, 11A*4, 17*4
55. Jack0k 1A*1, 20A*1
56. marcus1 1A*1, 9A*1, 11A*2, 12A*1, 19A*1, 20A*1, 23A*2
57. Photochum1 25A*1, 31A*1, 23A*1, 13*3
58. AirAir 1A(Q3)*1, 20A*1
59. av-trouvaille 6A*1, 7A*1, 14A*2, 16A*1, 24A*1
