Photo Gallery
The MK3 prototype has been tested for a month of regular use and it is working well with no issues to note and it sounds great.
https://flic.kr/p/2jA78sx
Also got a quartet of 6CA7's to try. They sound great. I think they may have slightly more gain as I initially perceived them as sounding better than the EL34's and KT77's but having retried the others, I don't think there is much in it between all three.
https://flic.kr/p/2jw5uur
I'm still working on the "how to build an all metal chassis" issue. I'm torn between the simpler 3mm aluminium plate on a wooden frame like I've already build against an all metal box like a Hammond 1444 folded aluminium chassis. Landfall Systems make an extremely good looking chassis but I think shipping and taxes to the UK are likely to be painful.
Looks good.
Not an amp however tube related.
These are pics from a friend of mine that builds a lot with my PCB's.
These are little regulator boards for the heaters of directly heated tubes, he is rather pleased with them.
Hi Guys,
I´d like to share some pics of my new 2A3H SET amp which is a special edition of the Sun Audio Uchida kit (based on a 300B kit). It is dedicated to operate the 2A3H only with its 2.8A heating current. A standard 2A3 can also be operated but it will be slightly overheated (2.6A instead of 2.5A heating current). All details and a report can be found on my blog but it would be much too much content for this thread.
2A3 Maniac strikes back!: Sun Audio Uchida Model SV-2A3H - Special Edition by 2A3 Maniac and Analog Tube Audio
Carsten (2A3 Maniac)
From your website: Consequently the designers of the 2A3H compensated these losses with a higher heater current of 2.8A instead of the 2.5A according to 2A3 standard specification! This means a 2A3H in a standard 2A3 application will be underheated and sooner or later this 2A3H would get damaged.
Are the transformers that tightly specced that it can't offer those 0.3A extra?
I do not really catch your point here:
(From 2A3 Maniac website) This means a 2A3H in a standard 2A3 application will be underheated and sooner or later this 2A3H would get damaged.
If you plug a 2A3H into an amp designed for a standard 2A3, the circuit will only provide 2.5A, even if the 2A3H sucks for more current.
In my amp the circuit is designed to provide the required 2.8A - no issue for the power transformer to provide it.
