100W Ultimate Fidelity Amplifier
Thanks for your reply.
Not using altium here, sounds like under eagle 'tStop' and 'bStop' are the way to go. Will try when I have to make a pcb again. Ordered last ones in JLCPCB too.
Outputs from eagle users would be nice to hear.
Previously i used Eagle CadSoft for PCBs. And yes you can use Stop and tStop layers to open the solder mask. When you order the PCBs don't forget to include gerbers for these layers. Also to be sure it is all correct, after generate the gerbers you can check them with some gerber veawer.
And my APEX A40. With modificated ground under the boards and transistors type in VAS. :)
Apex AX14 version Prasi Build
Somehow mine has 10mV and idle current via Q14 and output at 0.10~0.15mA with no setting.
its working ok and nothing is getting hot, should i get worried?:rolleyes: been up for the past 20min
That is better than mine. It sounds terrible, really distorted and low volume level.
The other channel I did works fine. I still can't find anything that is causing this one to register so low and not respond to adjustment more.
This is clone of APEX FH9.
Is this a clone that you are "ok" with? Would you recommend that an interested hobbyist try this kit to compare with their other projects (such as MX50X2 and MA9S2)?
Due to the very high interest in this thread I thought this "100W Ultimate Fidelity Amplifier" might be a suitable next project for me to explore.
Or do you recommend a different starting point instead of this kit? (Maybe it is or is not a good clone, and/or maybe you have another design that you would suggest instead?)
