Now there is: Release v0.3.2-beta2 * HEnquist/camilladsp * GitHubIs there a latest CamillaDSP armv7 binary in case I want to try it?
I would like to but today is out-of-town crayfish-party - I expect late tomorrow I might be in shape to waste time
Did you try to connect with the browser directly the the websocket of camilladsp?Tried to run this on windows: camilladsp.exe -w -p <port>
Get a notice in browser: "WebSocket Protocol Error: Unable to parse WebSocket key."
Tried to install on a second computer now, and realized the build artefacts are only available to logged in github users. If you are not logged in, you can't download the build.zip file. I'll have to make proper releases and update the instructions. For now, the zip is attached here:Is anyone brave enough to try out the gui? I have just written a (very) brief instruction here:
GitHub - HEnquist/camillagui-backend: Backend server for camillagui
It needs the latest CamillaDSP from the develop branch to work.
I haven't had time to try following my own instructions to set it up on a new machine yet. So there is high risk something is wrong or missing. So does anyone feel like potentially wasting some time?
Any feedback is appreciated!
View attachment build.zip
Totally my fault. I had assumed the gui was built into the latest camilla binary and that the port was for the web interface (have not had a chance to use camilla yet). I didn't see the other repo for the gui on github.
I simplified the installation a bit now by packaging frontend and backend as one zip-file.
Get it from here: Releases * HEnquist/camillagui-backend * GitHub
This version also fixes some minor bugs. pyCamillaDSP has also been updated, so be sure to get the latest one of that one too.
Thanks Henrik. I have tried to install it but didn't get very far. Problem is installing the dependencies on PiCorePlayer which is based on TinyCore Linux. viz :
python 3.6 or later
numpy
matplotlib
aiohttp
Python seems to be installed already but not sure if its a "mini" version. Numpy I think I have located but mathplotlib and aiohttp seem elusive (limited TonyCore repository) unless maybe I can get pip working. Of course there is no apt update and apt get on TinyCore!
python 3.6 or later
numpy
matplotlib
aiohttp
Right, it's probably a lot of work to make it run on TinyCore. You could try running the gui on another machine, maybe a VM or another raspberry running raspbian. The downside is that the gui backend won't be able to access files on the TinyCore system for plotting FIR filters and loading configs from disk.Thanks Henrik. I have tried to install it but didn't get very far. Problem is installing the dependencies on PiCorePlayer which is based on TinyCore Linux. viz :
python 3.6 or later
numpy
matplotlib
aiohttp
I downloaded https://www.diyaudio.com/forums/pc-...crossovers-correction-etc-73.html#post6324577
and satisfied requirements. Downloaded, compiled camilladsp with alsa (I run ubuntu 18.04, which has PA 11.x so it does not compile with PA) and websocket. I launched camilladsp like this
sudo ./camilladsp /home/osho/camilladsp-develop/exampleconfigs/stdio_inout.yml
But I am getting error when running the gui
osho@dtk:~/camillagui$ sudo python3.6 main.py
Traceback (most recent call last):
File "main.py", line 11, in <module>
camillaconnection.connect()
File "/home/osho/.local/lib/python3.6/site-packages/camilladsp/camilladsp.py", line 52, in connect
"ws://{}:{}".format(self._host, self._port)
File "/home/osho/.local/lib/python3.6/site-packages/websocket/_core.py", line 515, in create_connection
websock.connect(url, **options)
File "/home/osho/.local/lib/python3.6/site-packages/websocket/_core.py", line 223, in connect
options.pop('socket', None))
File "/home/osho/.local/lib/python3.6/site-packages/websocket/_http.py", line 121, in connect
sock = _open_socket(addrinfo_list, options.sockopt, options.timeout)
File "/home/osho/.local/lib/python3.6/site-packages/websocket/_http.py", line 201, in _open_socket
raise err
File "/home/osho/.local/lib/python3.6/site-packages/websocket/_http.py", line 176, in _open_socket
sock.connect(address)
ConnectionRefusedError: [Errno 111] Connection refused
It is clear, there is not service listening on 1234
The Readme mentions pycamilladsp, but what should be done? Thanks
raise err
Ok you are very close! The only thing left is to start camilladsp with the websocket server enabled. Like this:I downloaded https://www.diyaudio.com/forums/pc-...crossovers-correction-etc-73.html#post6324577
raise err
Code:
sudo ./camilladsp /home/osho/camilladsp-develop/exampleconfigs/stdio_inout.yml -p 1234
Oh, thanks, actually it is on the web page And maybe there is also my next glitch:
Launched like this:
browser at http://0.0.0.0:5000/ shows
404: Not Found
I have not found anything on the 35736.
Launched like this:
Code:
~/camilladsp-develop/target/release$ sudo ./camilladsp /home/osho/camilladsp-develop/exampleconfigs/stdio_inout.yml -p 1234
[2020-09-02T19:20:32Z INFO ws] Listening for new connections on 127.0.0.1:1234.
[2020-09-02T19:37:56Z INFO ws::io] Accepted a new tcp connection from 127.0.0.1:35736.
the process is listening
tcp LISTEN 0 128 0.0.0.0:5000 0.0.0.0:* users:(("python3.6",pid=31548,fd=7))
tcp LISTEN 0 1024 127.0.0.1:1234 0.0.0.0:* users:(("camilladsp",pid=31262,fd=6))
404: Not Found
You need to give the full path to the index.html:Oh, thanks, actually it is on the web page And maybe there is also my next glitch:
Launched like this:
browser at http://0.0.0.0:5000/ showsCode:~/camilladsp-develop/target/release$ sudo ./camilladsp /home/osho/camilladsp-develop/exampleconfigs/stdio_inout.yml -p 1234 ... [2020-09-02T19:20:32Z INFO ws] Listening for new connections on 127.0.0.1:1234. [2020-09-02T19:37:56Z INFO ws::io] Accepted a new tcp connection from 127.0.0.1:35736. ... the process is listening tcp LISTEN 0 128 0.0.0.0:5000 0.0.0.0:* users:(("python3.6",pid=31548,fd=7)) tcp LISTEN 0 1024 127.0.0.1:1234 0.0.0.0:* users:(("camilladsp",pid=31262,fd=6))
404: Not Found
Code:
[URL]http://localhost:5000/gui/index.html[/URL]
Thanks, sure, it was there and it is the Readme again. The Gui is in the browser now.
I just blindly stuck with ======== Running on http://0.0.0.0:5000 ========
without going back the Readme.
Great! Play around and let me know what you find that is weird or doesn't work properlyThanks, sure, it was there and it is the Readme again. The Gui is in the browser now.
Since the digiface doesn't have a linux driver the pi4 won't work. A mac mini is probably the best choice then.I ordered a RME Digiface and hope to play around with it next week. Is still a pi4 a good contender for a comp platform? Or should I get an used Mac Mini? What do you say?
I have been working a bit more on the various parts of the gui and updated them all.
In the gui it's now possible to plot the combined response of a Filter step of the pipeline.
There is also a much improved readme that should make it a bit easier to set it up: GitHub - HEnquist/camillagui-backend: Backend server for camillagui
pyCamillaDSP got a major change, it is now split into two libraries:
GitHub - HEnquist/pycamilladsp: Python library for handling the communication with CamillaDSP via a websocket.
GitHub - HEnquist/pycamilladsp-plot: Plotting tools for CamillaDSP
The first one handles only the websocket communication and requires only the websocket-client package. This part is basically unchanged from before, except that I added CI tests with 100% test coverage
The second one handles all plotting and requires numpy and matplotlib (but not websocket-client). This also includes the "plotcamillaconf" tool that is meant to be an improved replacement of the show_config.py script.
Finally there is a new beta of CamillaDSP, 0.3.2-beta3. This fixes a bug where the active config wasn't cleared when shutting down the processing pipeline, so the websocket server replied with the previous config instead of none.
Does to new version change the URL? I am getting 404 for the http://localhost:5000/gui/index.html
I do not use your build in releases, because Ubuntu 18.04 does not come with GLIBC_2.29, just 2.27.
What Fedora version do you use with CamillaDSP?
- PC Based
- CamillaDSP - Cross-platform IIR and FIR engine for crossovers, room correction etc.
