ES9038Q2M Board
A good, continuous ground plane would be a very good idea. The ground plane of the output stage board should be directly attached to the ground plane of the dac board. Did you take a look at how I did that for the through-hole output stage design I made at request of some forum members? Also, if you carefully read what ESS has to say about output stage opamps in relation to the dac chip, its about the same as what I did. Many people fail to study the pertinent information: http://www.esstech.com/files/4514/4095/4306/Application_Note_Component_Selection_and_PCB_Layout.pdf
EDIT: By the way, a single-channel 40MHz scope for free is a pretty nice addition to the tool kit. It can be used for many things, so learn everything you can about what it can do, how to configure it for different measurements, and general use of 10x probes. Some good info in: https://download.tek.com/document/02_ABCs-of-Probes-Primer.pdf
Also: http://ecelabs.njit.edu/student_resources/XYZ-Scope.pdf
There is no virus in the through hole download, nothing executable at all. Your antivirus program is reporting a false positive if anything.
Its just a zip file mainly with an .rtf file that can be read with Wordpad or any number of other programs. It contains text and pictures of my output stage project in various stages of completion.
One of the pics showing how the two ground planes are attached can be seen below below.
Pcb uses schematic from Mr.Slim in post #3003.
Can be some errors and like I saý alot of designerrors like groundplane, supplylines etc.. And due to some problems to collect parts from local supplyer the choice of components can look a bit strange…
BR //Daniel
Hi Daniel it could be great maybe a small group buy with your output Pcb's if you have time to optimize it bit with help from forum members😊
Thx
Happy building
Daniel,
IIRC, don't think anyone ever got that circuit to work. I know ESS does not use it on its ES9038PRO evaluation board. Besides, if it did work why wouldn't the cheap Chinese dac boards use it? Its simpler than the awful sounding voltage mode circuit they are using on the board you are planning to mod.
I solder Victors I/V stage from the 9018 thread. Also did the avcc mod.
We tried the Dac yesterday evening and the sound was really ok.
One problem appiered, we use optical input and after one hour we start to drop ”lock”.
Every 3-6 second a click sound and the lock led flashed for half half a second.
Maybe a bad solder?
BR// Daniel
Hi Daniel,
AVCC and the output stage should have no effect on 'Lock' status of the dac chip. Optical goes into the optical receiver and from there goes through a minimal number of passive components and then directly into one of the pins of the dac chip. Also, the optical receiver is powered by 3.3v from the dac board. I would suggest to look at the signal coming out of the optical receiver with a scope both when 'lock' operation is okay and when a fault is indicated. If you see a change in the signal on the scope, most likely that would indicate a problem with the optical receiver, optical cable, or the source device. Either that or maybe the 3.3v to the optical receiver is intermittent (doesn't seem likely).
Hello,
I haven’t got time to look at it yet, but will try maybe tomorrow.
I was thinking of cold spray and if i can’t find the problem i will go and buy some.
I’m thinking of change the optical reciver to a TORX 147, have it at home.
Regarding the avcc i did it as in the post #3003. Didn’t change anything except for the capacitators at the output (10uF), i didnt have them at home but put a 3.3uf cheramic.
As for I/v stage i did like Victor in the 9018 thread. I will change it to a copy of the one in post #3003 when PCB arrive.
Chinese ES9018K2M I2S DAC
BR // Daniel
Daniel,
Presumably, you understood that the +3.3v label in Victor's schematic refers to the AVCC voltage for the dac channel that the output stage is attached to?
Also, ceramic caps at the AVCC output may not be such a good thing. Most are non-linear and they also tend to be piezoelectric. Might want to replace those when you get a chance.
Hi Mark,
Sorry, i linked to the wrong schematic. Link is corrected now and i build the schematic in post #151. So i have 1.65 v from avcc to outputstage.
I’m really happy with the sound if i manage to fix the lock problem when trying.
Regarding the cheramic caps at output for the avcc, what do you think is better? El-lyt? Film?
BR// Daniel
Regarding best type of AVCC output caps, I never decided. Also, it may depend on what opamps are being used and how they are powered. I know that bass may sound better if the AVCC opamps have a lot of local energy storage in close-by large electrolytics from the rail (or rails) to ground.
Another big sound quality improvement can be had by lowering DPLL Bandwidth as much as you can without encountering instability (loss of lock). (I doubt your optical SPDIF problem is related to the register setting, the board's MCU leaves it at default which is very tolerant of jitter IME).
