Wayne's BA 2018 linestage
gain? ground?
Thanks to all helping me out on my various questions.
2 more:
Gain: I kinda understood how to change gain through the 2 resistors (R16+R17)/R17. Clear so far. But what are reasonable steps—should I increase R16 (mo' gain) or decrease R17 (mo' gain)?
Ground: I was looking around for advices/hints at good grounding schemes...
and found most builds with no signs of grounding the amp other than through the PCBs and of course the transformer's earth...
OTOH, there was russellc I believe who went the firstwatt way with a star-ground-connection (again, ?) with a CL60 somewhere... is this the way to go?
thanks!
david
Grounds and their problems are funny things. In my builds, (might add I have NO electronics background other than what I have learned from DIY!) I followed 6L6 build guides.
I figured why not follow the tried and true method. Then, after it works and I have asked enough questions, I might bring on some change.
Check the 6L6 build guide on the BA3 as preamp. I used the same grounding scheme with that pre.
Follow what works if you are not an electronics whiz like many who share here.
When that works, you have a good foundation for any mods. Makes it a lot easier to troubleshoot if it doesn't work...
Russellc
I did my audio ground same as on the whammy and my build is dead silent. 🙂
It does look like a cap but I thought the idea was to float the signal ground from chassis ground via a thermistor and/or bridge rectifier. Keep them isolated unless something goes electrically very wrong... Maybe that's only an amplifier thing? I'm interested to know the answer too.
compact and very clean! (Is this a capacitor at the signal's ground?)
anyway, c'est très cool 🙂
It was done on the whammy as recommended in the build guide so I did it on the Linestage too. Very effective. No hiss, buzz, hums or anything. Crank the volume right up with nothing playing and it's as silent as can be.
Since this has balanced inputs, is there any easy way to build it with balanced outputs? Without building two of them? I live in a very noisy environment and get terrible hum when using single-ended cables...
here it is, but make it on own risk
no reason it would not work flawlessly right off the bat, but it also could ask for some taming
edit:
you id mention balanced inputs, I did this with original schematic from post #1, where input is strictly SE
can't remember where iteration with Bal input is posted
