Also you could double check if power is lost on too low frequencies. It may help to filter in the 10-25 Hz range...
That is a good idea, which i will follow as well...I just started to measure and figured that preset 3 somehow did not get uploaded, so there seems to be no filter....I corrected this with a fourth order LR at 60hz and gave the Sub a gain of +15db from 0Hz to 60hz....
...well, no protection LeD anymore....so, the fa251 seems to be actually strong enough...
Nevertheless I will now optimize the sub firther, see what parallel drivers will do etc. But I can say already that two Ripoles bring my speaker to a system from 25Hz up flat, I could not have expected any more...
When the optimization of these other setting i done, i will measure time delay and set that right and then we can talk about the SQ...I like already what I hear thought...integration seems to be seemless.
By the way: Currently I have only one input cable used for the Highlevel inpit, so left speaker is on the left speaker input, right speaker input is empty...am I wasting input level that way ? So, if I give the input signal of the left speaker to both inputs in parallel, will i gain +6db ?
Ripole uses opposition for excursion reduction. Active cone resistance helps lower the fs and limit excursion.Linkwitz used 60W amplifiers in his open baffle design with 28 mm linear X max Seas woofers, and this seemed to be sufficient to bottom out the woofers:
LX521 Description
You could parallel the woofers as Ncore should be able to drive that load.
Not so much because of opposition, but more because one side of both woofers is "slot" loaded (1/3 to 1/4 the Sd following Ridtahler's schemes.
That way he created the typical "Ripole" radiation instead of the typical "figure of eight" dipole radiation.
Question, are the LS Pin Outs on every FA XX1 soldered parallel? For example there are 4 Pins. 1LS+, 2LS-, 3LS+, 4LS- . I can combine 1 and 2, 3 and 4 or 1 and 4 or 1+3 and 2+4 and it all works which would suggest that they run in parallel, but I wanted to be sure.
Hi everybody,
in the Fusion manual, page 16, the BTL output power i.e. for a FA122 is given:
BTL 200W@ 4Ω / 250 W @ 8Ω
normally an amplifier delivers more out power with lower driver impedance afaik...
is this an error or is the real behaviour of the fusion amps?
thanks
thanks
Since BTL is a bridge mode, for a 4 Ohm bridged load the amp delivers roughly 2x the output as to 2 Ohm load individually and the Fusionamps max output is lower to 2 Ohm than to 4 Ohm.
The New Hypex Fusion Plate Amps
Hello,
I finally took the plunge and got myself a pair of F503. Its been an uphill battle trying to set things up, even going with the simplest route for starts, triamping my passive speakers.
My problem right now is that my master module on he left suddendly stopped recognizing the HF channel. It shows on the filter design but not on the device settings, and doesn´t output. When plugging the USB cable as per manual, it doesn´t recognize the module. It shows the correct firmware, but lists Unknown on the module type, and on device settings it only shows the channel one and two, no matter how many times I change settings, force slave or master, upload different firmware versions, or use a different USB cable.
On the other module everything is fine, all channels are active, module recognition ensues as soon as I power up and shows up correctly,(FA503), with this computer and any of the two USB cables I have, so it definetely is some problem on the connection on the other module, and not the my pc or cable..
Does somebody have some advice before I have to contact Hypex, something I haven´t tried, not invalidating warranty of course?
Its a bit frustrating, I have them for like a month, have had not much time to try and get them working,and had only plugged them in a couple of times and try to set them up and have a listen with the two power channels active, today was the first day I was actually going to use the HF channels on the tweeters..
That USB connector always seemed a bit loose from the start, but worked with no issue till now...
Hello,
Contact Hypex, the module lost it's configuration settings. They will send you a special program to restore this.
Hi, thanks for the prompt reply, hope that is all
there is..Any reason why that happens, and ways to prevent that? ...Can the unit go heywire in the
in this state, or is it safe to use the remaining channels meanwhile ?
Ok, just to close the loop regarding the ripole and the fa251:
- I paralleled the highlevel-input, so used left and right speaker inpit for one channel in parallel which brings 6db gain.
- I asked Axel Ridtahler if parallel chassis is fine and he said no prob as long as the amplifier can stand it, so now they are parallel with 1.6ohm, no protection led, but 6db more real pressure if needed
- I needed to learn the software, which needs some trial and error as there are as well some bugs when trying to automatically write settings from one preset to all others. Dont trust this function, not in the filter desgner nor on the EQ page. They simply do not write to the other presets. Each needs its on write command.
So, now its working well and is hammering the ripoles...quiet impressive that they are sonically so transparent. Just like your main speaker got bigger.
hi all
just bought 2 FS503. my first plate amp!
need to know where can i mount the amplifier?
i have a open baffle speakers with a 18' woofer, so i was afraid the strong magnetic field will damage the FS503. if i mount it near that woofer.
thank for helping
Lee
thank for helping
Lee
hi all
thank for helping
Lee
external boxes
An open baffle speaker has no box...
A small MDF box works fine for the Fusion plate amps. I just have it on the floor next to my open baffle speakers. Also better regarding vibrations...
Fedde
Fedde
I also use open baffle. It needs some kind of feet, or maybe u baffle. A "Faraday" enclosure should be sufficient, but off course we might run into space issues and a separate box is the only way.
The manual said regarding material "Class V-0 or V-1 from EN-IEC 62368-1". Is that not importend? It's probably about fire safety.A small MDF box works fine for the Fusion plate amps. ...
Fedde
- Class D
- The New Hypex Fusion Plate amps
