The Black Hole......
Bill,
Noise level is directly related to impedance! A power amplifier should just by that be 20 dB ish quieter then a preamp. The type of noise + distortion curve shown in the BT review is the classic noise level falls until it reaches the low point where the distortion rises. As the rise occurs at a point above the actual operating point the data is not very useful.
Now when measuring audio power amplifier distortion into a resistive load you not only have lower noise but again a not very useful measurement. My experience has been the conversion from electrical power to acoustic power is not of any use with resistors! 😉.
Actual loudspeakers seem to have reactive loads. Every time with a reactive load like an actual loudspeaker system for a test load the distortions I measure rise by very significant values.
I have never measured an audio power amplifier into a real load that had anywhere near the static measurements occasionally shown.
The best resistors I have looked at power levels above 1/4 watt can barely do -160 dB on distortion. So the trade off becomes noise vs distortion, not very surprising.
As to detecting signals buried in noise there is very good data on those thresholds. Surprise...not, the human perception process peaks for that in the midrange. Higher frequency harmonic distortion is less perceptable, but should not be confused with rising high frequency distortion that is a sign of other problems such as intermodulation or even wrap around distortion.
Bill,
In pro audio the original audio power amplifier gain has been a voltage gain of 20. So with a CD output of 2 volts and an 8 ohm loudspeaker that would provide 200 watts. Probably enough to damage most home loudspeakers.
As pro preamps can provide 10 volts or more that should be enough to smoke almost all transducers. However for marketing purposes some amplifiers have higher gain so they sound louder in demonstrations. Some folks prefer to have all of the amplifiers in their systems clip at some fixed input voltage often around 1.4 VACRMS so the gain increases as the output power goes up. (Holy VU meter hangover batman!)
Obviously a preamplifier is required for sources such as vinyl records. However CDs, radio tuners and tape decks often really don't need gain in a control selector system.
Although there is some very good stuff going on using the purifi woofer in the multi-way forum here. It's expensive but you can get some very impressive performance from a 6.5" woofer in the right cabinet. Handy for those of us without room for larger speakers. And I am secretly jealous of those with room in their house for Fridge sized cabinets and 15" drive units whilst remaining married.
Edit: some people have dedication well beyond what I could get away with.
Simon: The challenge as you know is meausuring the THD* on its own as you are generally noise floor limited at that level. But the LM3886 based amps TomChr does are one example. Hans has just published his amplifier schematic that does fractional ppm. I still prefer to look at the 32 tone test results.
Attached some measurements from Bruno's G_word preamp at +18dBu. Basically measuring the AP noise floor. That is what I would like my preamps to do. Total and utter overkill but if you can...
* Whilst accepting that some of the greybeards here just think thats yoof being lazy and expecting the analyser to do it all with no brain required.
Relatively easy to achieve with decent opamps these days. Regrettably, some say opamps are no good ‘for the sound’.
The fittest usually meant the strongest, most stable and enduring. Research by the Center for Cognitive Neuroscience at Duke University showed that the most prosperous species survived based on partnership and communication, rather than physical victory over rivals.
They measured it at 4 volts, what source to a preamp is 4 volts?
Just about every balanced DAC out there? Sony/Philips set the standard for CD output at 2 volts unbalanced, which is 4 volts balanced.
I have measured countless DACs with 4 volt output and some that go way above that (pro DACs). Here is a budget $200 balanced DAC:Schiit Modius Balanced DAC Review | Audio Science Review (ASR) Forum
index.php
I test preamps by simply using unity gain (4 volts in, 4 volts out). In a pass-through mode like this, there better not be a lot more distortion.
Parasound Halo JC 2 line preamplifier Measurements | Stereophile.com
I do wonder why ASR didn't try a bit harder to replicate the stereophile results. Or even email JA with some questions.
You can't replicate JA's results because there is insufficient documentation on the parameters used for his tests. No THD+N measurement for example is valid without bandwidth being mentioned. The wider the bandwidth, the more noise and distortion products are captured. Here is my graph with bandwidth clearly stipulated on top:
index.php
There is no such mention in JA's tests.
He also does silly things like use 600 ohm as output load. That is unusually harsh load and doesn't resemble any power amp input impedance that I know. You want to complain about something, you should complain about JA's tests, not mine.
