Shanti Dual LPS 5V/3A , 5V/1.5A
I just purchased a Shanti and am planning on upgrading the DC power leads.
What is the brand/model of the internal Shanti connectors for the 5V outputs?
It appears to be Molex or JST, but I'm not certain.
Part numbers for the connector and terminals would be very helpful.
Physically, it's a mini-me version of Shanti, which I consider to be big & ugly, albeit with clean sound. I have Nirvana powering an extra DigiOne which is not in my preferred sonic path for the time being, so I can't comment yet about how it compares. More later.
cdsgames,
is it a good idea to run the Logitech Media Server on the Usbridge Signature?
Compute module 3 used in Usbridge Singature has a single-lane (shared) LAN and USB, am I right? I guess that running the LMS on the Usbridge Signature is not recommended for the best performance/sound.
Hello @cdsgames, could you please clarify if Audiophonics wording about Nirvana is correct when they write:
"This ultra low noise SMPS power supply offers two power rails each with a voltage of 5V and a maximum current of 2.85A".
Is the 2.85A amperage total or related to each of the 2 5V outputs?
I checked on the Allo.com website but could not find specific info.
-And would it be appropriate to use both connectors from Nirvana to my USBridge or DigiOne Signature like I do now with Shanti?
Yes you can but kind of defeating the low noise output if one connection is wired to a noisy device and yes you are sharing the one rail maximum output
Its like having one PSU with a split cable (Y). We just give the USB connector for convenience .
Shanti comes with direct soldering (wire) on PCB , but you can also use a connector part number is KLS2-128I-5.00-02P-4C
