• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Shanti Dual LPS 5V/3A , 5V/1.5A
I have no idea when it will be ready , I am just testing the power rails. No driver was made...so it will take a few good months (Oct maybe)
This new hat will not be compatible with USbridge in a alu case because its made for a specifc case with a RPI4. If you have a PCB usbridge you can use it but output will be a bit wired
Hi @cdsgames
I am asking if I can use the old boss (or another hat dac-ropiee compatible) into signature, with usb output and dac output simultaneously?
I use ropieee and I do not use aluminum case.
Full Nirvana readings available .
Please note that all readings are taken with full signal !!
THD at -126 to -123.5 . THD +N at -114.5 to -115
Independent testing will be available on Rev with a better AP , frankly I expect reading better THD by 0.5db.
Production is in full swing for both Nirvana and Rev Dac. I hope to have them ready in a few short days.
Each unit is hand tested.
