Hello @cdsgames
When will Shanti be available in the EU ? Currently out of stock in EU store.
Nirvana is shipping already from India , EU stock on the way , Shanti will be back in stock in 1 week or less
Rev is shipping in 1-2 days from India
I just purchased a Shanti and am planning on upgrading the DC power leads.
What is the brand/model of the internal Shanti connectors for the 5V outputs?
It appears to be Molex or JST, but I'm not certain.
Part numbers for the connector and terminals would be very helpful.
I will check for terminals
Nirvana is in stock in EU and India.
Rev is in stock in India and EU will receive stock Monday/Tuesday.
I ordered Nirvana on June 5th, and received it here in the U.S. on June 17th -which is the quickest yet from Bangalore compared with my USBridge, DigiOne, DigiOne Sig and Shanti experiences.
Hi BTinker
first impressions on sound , build quality , anything you want to share (as usually bad and good)
Physically, it's a mini-me version of Shanti, which I consider to be big & ugly, albeit with clean sound. I have Nirvana powering an extra DigiOne which is not in my preferred sonic path for the time being, so I can't comment yet about how it compares. More later.
cdsgames,
is it a good idea to run the Logitech Media Server on the Usbridge Signature?
Compute module 3 used in Usbridge Singature has a single-lane (shared) LAN and USB, am I right? I guess that running the LMS on the Usbridge Signature is not recommended for the best performance/sound.
Hello @cdsgames, could you please clarify if Audiophonics wording about Nirvana is correct when they write:
"This ultra low noise SMPS power supply offers two power rails each with a voltage of 5V and a maximum current of 2.85A".
Is the 2.85A amperage total or related to each of the 2 5V outputs?
I checked on the Allo.com website but could not find specific info.
-And would it be appropriate to use both connectors from Nirvana to my USBridge or DigiOne Signature like I do now with Shanti?
Asked whether Nirvanas outputs are isolated, cdsgames answers that Nirvana has only one output (see here: Post#6238550)
cdsgames,
You can run LMS on USbridge Sig up to DSD 512 with no penalties on sound
Nirvana has only one output and 2 ways to connect...but its the same output
ok, but... can one use both connections at the same time?
(sharing those 2.85A between the two, I guess)
Yes you can but kind of defeating the low noise output if one connection is wired to a noisy device and yes you are sharing the one rail maximum output
Its like having one PSU with a split cable (Y). We just give the USB connector for convenience .
Shanti comes with direct soldering (wire) on PCB , but you can also use a connector part number is KLS2-128I-5.00-02P-4C
ok, but does the LAN is separated from the USB in the Usbridge Signature?
Yes it is. Our architecture is different that RPI .You can use LMS on USbridge Sig up to 512DSD with no penalties on SQ
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
