germanium Preamp?
I am surprised to read these low noise levels achieved with Ge-transistors. Like KayPirinha my experience with the Ge-types available to me at this time like OC70, OC71, AC122,GFT32, OC304 etc were quite noisy compared to the upcoming Si-BC109.
Yes, especially the AC122, as used by vsmusic, wasn't exactly known for low noise.
There were better Germaniums in terms of noise, btw, the AC150 for instance.
Best regards!
Agreed. But I expect a phono preamp to be almost noiseless especially if the tonearm is lifted.
Best regards!
: ))))) ...Then listen to the silicon preamp . And I will continue to use germanium - I have 2 of them ( probably there will be more ) DSCF7660а.jpg
Best regards!
The noise level of this preamp (with AC-122 transistors) is less than minus 70 dB . I took measurements using RMAA . This parameter is quite enough for me . I use vintage players ( pioneer and Kenwood), vintage Empire cartridges ...Why not a vintage preamp ?DSCF5333а.jpg
I use vintage players ( pioneer and Kenwood), vintage Empire cartridges ...Why not a vintage preamp ?View attachment 853317
Of course! I'm also on vintage gear (Dual and Thorens TT's from the 1970ies and 1980ies, Shure, ELAC and AKG catridges, tonewheel Hammond organs, airhead BMW's, steam locomotives…).
Best regards!
Edit: Your builds look phantastic 🙂!
If the sound is so much better with Ge...
...which still has to be proven…
...the noise issue can easily be overcome by paralleling.
Never noticed any design using paralleled Ge devices, most probably due to their enormous manufacturing tolerances. You'd have to carefully select form a big lot of specimen that aren't in production since a long time.
But agreed: That Shure M-61 offers astonishing data, especially for a Ge powered phono amplifier. Which devices are used in here?
Best regards!
Best regards!
The SHURE product used American transistors . But the phono scheme itself was the same as that of Telefunken TV-206 . I don't have transistors like SHURE used . So I can't compare them to AC-122 transistors . Telefunken used AC-122 transistors .I made a device like Telefunken's , using AC-122 . Power supply-32 volts . And this has been working for me for about 5 years
