Kii Three / D&D vs. PSI Audio actives - DSP vs. analog crossover
I'm really not that much of a "vinyl guy". I do keep a decent turntable set up, but mostly just to humour a few of my audio buddies who think it's still the year 1979.
My analogue source is that of reel-to-reel tape. I have two machines. One allows playback of 2-track master tapes at 15IPS, the other is quite nice for 4-track 7.5IPS
My speaker system is very well thought out and operates with an analogue active crossover system. This particular unit uses discreet transistor circuitry, emitter-follower, single end based. No op-amps.
The speaker system is a 4-way, high efficiency approach. 100db/watt from 25-30K Hz. It is time aligned and each of the 4 frequency sections operates in a linear fashion well withing the designated crossover bands. There is no need for any sort of dsp twiddling. The listening room is treated with many acoustic devices. There is no slap echo. There are no nasty reflections or does there require any sort of goofy device such as a di-pole.
The system resolution and retrieval of fine inner detail is quite shocking to those who visit, and listen for the first time. We, the listeners are not transported to the venue, but rather, the performance is delivered right into the room. Listening to Chet Atkins, "Most Popular Guitar", he might as well be sitting on a bar stool right in front of us.
Replacing my custom crossover with some sort of behringer/or/equivalent mini-dsp would most assuredly completely ruin what I have accomplished.
It's clear you enjoy your system very much and are quite proud of it.
I second hi-fijim's congrats.
Have you built a large collection of master tapes? They look to be terribly expensive 😱
I used to end up only wanting to listen to the very best recordings, like the Sheffield LPs etc, because I had done everything i knew to my system and room, and then source material became the defining objective/constraint.
I think that happens to me when I focus all my attention on one system in one room. Ears get blinders on so to speak.
Anyway nowadays, I keep multiple, very diverse systems running, and seem to be constantly trying something new.
I cannot begin to say how much dsp has helped all the multiple diverse builds....and how generally excellent they have all turned out....many actually exceeding the fine store bought gear accumulated in the analog era.
I use the same simple formula on all....make the best acoustic design i can through sim and then prototype trial and error....then correct driver by driver with minimum phase, and sum with linear phase xovers. Simple really.
Anyway, you're happy with yours, and I'm happy with mine , cool 🙂
Btw, if you want a passive eq that appears in full keeping with the system you describe, I have a Manley Massive Passive i'd be willing to put a price on.
How can you achieve the cardioid polar pattern with an analogue crossover? A short explanation with some best-practise examples would be very nice.
You don't even need a crossover to achieve a cardioid pattern; a dipole loudspeaker already does it purely acoustical ....
Let me reverse your question: Why would you need DSP to create a cardioid pattern in a design like the Kii (front- back- and side-firing woofers)??
Cardioid with a DSP, gives much more control of the situation.
Dipole does not. I might cancel itself out in some areas... but not in a controlled manner as a DSP controlled cardioid..... this should be obvious 😉
Moderne techniques are sometimes smarter.... why is that so hard to believe?
If the drivers and the loudspeaker cabinet is build for a simple analog crossover.... great. But if you just want a little bit of precision and use a bigger variaty of drives.... an active solution with a DSP is really the way to go. Most analog speakers that I have heard - no matter the price. Has to live with some kind of compromise, since they cant have good transparency, unless they use few components... but they need many components to obtain good precision.... so many times I experience passive speakers as fighting themselves - not really being able to do anything good..... medium.... ok .... but never really shine. Oh... a few do play well... when they have access to special drivers and other unique situations, that normal diy people cant come close to.
But as a diy hifi-guy.... an active system really makes it a new world of possibilities.
Hello friends, this is my first post and i really need your help.I have just finish my new speakers with 1 x woofer eminence Delta 120A ,2 x midrange celestion TF0615MR(close back) and 2 x tweeters Beyma T 2030.I have a big problem with the crossovers, can you help me found out what crossover should i use for it ? I use an old crossover from my previous speakers but the result is terrible.I cant use the softwares -i dont understand those-is there someone who can design a crossover for me and what componets should i use? I am given you specs from the drivers :12" Woofer
400 W RMS,8 Ohm,54 Hz - 5 kHz 6'' midrange 97 db, 8 Ohm,50 watt rms,500-5,000Hz Tweeter Power: 15W
Impedance: 8 Ohm
SPL: 95dB / W / m
Extremely high quality high-end tweeter from 2.5 kHz Thanks!!!!!
I'm sorry to inform you.... that it's not going to happen. not because we dont want to.... but because specific driveres in an unknown box... is impossible to predict.... if you want it to be good.
If you build the speaker from some kind of kit.... please post which one. But if it's just some freely thought out design....then you have to measure and find out exactly what each driver is doing. Please do yourself a favor and read up on how to measure... I'm not kidding. Read something like this for starters:
Loudspeaker measurements
And maybe ask the moderators to move your post to a new thread, so that you can get specific help for your project 🙂
Agreed that DSP is the way to go nowadays, but the question of the TO was if speakers filtered/equalized by DSP would sound better or worse than speakers filtered/equalized by analog circuitry.
Until now I have not heard a strong argument why DSP should be superior, apart from "ease of use".
The DSP applied to Kii can also be replaced by analog circuitry, even to control a variable cardioid pattern.
About passive vs DSP active speakers: I have heard many good sounding passive speakers over the years and actually not so many good sounding DSP controlled speakers. However, to be honest, I haven't heard Kii and D&D.
Would you mind giving me examples of a few DSP controlled speakers that did not sound good (assuming they were known commercial offerings) and which passive ones you considered to be good sounding, as a kind of a reference?
YSDR wrote -
The Hypex Fusionamps runs at a very specific 24 bit 93.75kHz sampling rate AD-DSP-DA (and certainly for a good reason) and the processing works at 32-bit if I remember correctly
Thanks, I was pulling my info from memory, and of course you are correct. You seem to be correct on all things related to Hypex fusion... 🙂 I never got the chance to express my thanks for your Hypex wisdom. I read most of your posts (mostly directed to other people), and collectively those posts made my entire Hypex fusion project a smooth and trouble free event.
I like the original question, it has spawned a lot of discussion. But I am not sure we are any closer to answering it.
Let's stipulate a relatively simple loudspeaker with a 6 inch driver (Satori MW16P) and a 29 mm soft dome tweeter (ScanSpeak D2905/9500). These drivers would be well matched, and a talented designer could put together a great sounding passive crossover.
Now lets assume that we use DSP to mimic the passive crossover... i.e. we match the woofer rolloff and any baffle step adjustment... we match the tweeter high pass slope, and also mimic any notch filtering the designer may have included... but we do no additional EQ within the drivers pass band... we limit ourselves to mimic the passive crossover. We limit ourselves to IIR digital tools which mimic analog circuits.
If I believe that the A/D/A process will inherently degrade the sound (even if just by a tiny amount), then I will conclude that the DSP version will, at best, sound nearly as good as the passive version... but only with the most flawless of A/D/A processing. The DSP version will never sound better... how could it? And in most cases it will sound inferior to the passive version.
If on the other hand I believe that the latest A/D/A technology is sonically transparent with no degradation, Then I will conclude that the DSP version will sound the same... Further, if I am one of those people who believes that a driver sounds best when connected directly to an amp... that passing a lot of current through large capacitors and big coils involves an inherent degradation, than I will conclude that the DSP version could sound better than the passive version.
This thought experiment ignores many of the powerful capabilities of DSP for the sake of discussion... My point is that what we believe (our starting assumptions) will steer us to a conclusion... We are not really arguing about the Kii Three and PSI Audio, we are arguing about our fundamental assumptions.
Although I don't have a big wisdom, but imo if the equalization and crossing is totally the same then the difference (if any) comes from the implementation of the two technology (analog vs digital), like the realization of the circuits, knowing the bottlenecks and drawbacks of both the used parts (and how they reacts to each other) and topologies etc.
As a manufacturer (not audio equipment) I am always wondering how just a few other manufacturers use the potencials in their products. The market is full of flawed products like the engineers don't really knowing what they are doing from technical point of view, meanwhile they are making a lot of money sometimes. Of course the pruducts are works, but far from optimal and a few modify here and there and the result would be a much better product. Of course sometimes the flaw are intended in the product.
Maybe that's just a bad generalization on my part, projecting my experience to other industries, so I apologize if I am wrong.
An example which was written here before I think: we can't say that a Mercedes is better in general than a BMW, maybe the former have more reliable models (I don't know), but sometimes the latter makes equivalent or even better models.
A wrong assumption I saw in this topic is that a 3000-4000$ DSP unit is as good as can be. The reality is that we don't know until measured (or listened). We can find examples relative easily that sometimes the price of an audio device have very little relation to the objective sound quality.
@hifijim
Thanks for your kind of words! I just like the Hypex FA-s, and wants to help others to find their joy with this great amps eqiupped with DSP.
It is not using one technology to clone another, take it back to the original design goals.
Let's say the goal is to design a speaker of 50W with a flat response and low phase shift. What do I need to get me there? Or, which technologies will get me there?
Or with simple op amp circuits like done by Linkwitz:
Active Filters
But that is NOT delay! It's phase shift. Not the same.
Why do you keep asking this? What do you think you'll get out of this question? It won't help you answer anything. You'll just hear an oppinion about speaker A, B C and D.. nothing else.
I agree with 4real. I would add that for a bad-sounding DSP speaker, there may be a number of reasons why it sounds bad. Maybe not due to being DSP controlled or neither due to being digital (having AD and DA converters) at all.
The problem was that a conventional 3-way "all 3 drivers on the front" speaker was chosen as a comparison to two un-conventional >3 speakers "som on the side" type speakers. That confused a whole lot ;-)
It's not a 10-1 win for digital but personally, if I had to choose, I'd go digital.
