Quick question for you knowledgeable folk. Is it possible to use the modules and apply some modifications to make a 2 channel amp from the FA253? DSP no longer needed just want two NC250 amp channels
Yes. If the NC100 (tweeter channel) is no longer needed, set the gain to the lowest value possible, which I believe is -144 dB. Since you no longer require any DSP function, you should remove all filters from the two NC250 channels. Then add a single unity filter to each NC250. This will give you two full range channels with no EQ.
In my case (no tweeter module) I unplugged the input/DSP unit completely, removed the amp from the main plate, and used it as a NC122MP amplifier. BTW, the main plate makes a great drilling template if you move the amp to a new box.
Thanks will do a bit more reading then. I’m no electrical engineer so hopefully not too difficult.
Will need to investigate cases with two inputs and outputs to put it all in.
Sorry it's ask question day. Should I try and make a 3 channel amp for LCR (or find somoene to do it for me) and manage to get a 3rd NC250 is the power supply for the FA253 sufficient?
I would advise to look up the Purifi amp with its stereo test board. This may be easier to use for you... and probably a bit better even...
Fedde
Fedde
Is there an NC250 that doesn't include its own SMPS?Sorry it's ask question day. Should I try and make a 3 channel amp for LCR (or find somoene to do it for me) and manage to get a 3rd NC250 is the power supply for the FA253 sufficient?
Fedde
Purifi is really great, but as per Benchmark, the NC400 seems to be a best value for the moment.
In my opinion, the best choice regarding the performance / price ratio is the NC250MP, I get them @ 125$ / board. No need to spend too much for a great DIY Ncore.
Most major brands sell their dual Mono NC250 more than $800, it's crazy !!!
You can get a Purifi finished amp (2x400W) for 1350 euros. This is the best price I saw.
Check audiophonics NC252 build, not a bad price imo:
AUDIOPHONICS MPA-S250NC RCA Class D Stereo Amplifier Ncore 2x250W 4 Ohm - Audiophonics
Check audiophonics NC250 build, not a bad price imo:
Audiophonics is a great dealer in France, they propose the best priced Ncore amplifiers. I would go for a double mono Ncore NC250MP instead (my point of view).
The choice is given, but the price is almost double for 2 monoblocks.
Edit: more like 1.5x price, after all, it's not bad.
You re right.... Major brands, as already said, are selling double Mono Ncore @ more than $800 ! I am used to pay about $125 for a Mono NC250MP, so $250 for a double Mono Ncore ! that is a bargain for me 🙂
I need to adjust the phase in the crossover region and cannot adjust the phase enough using the all pass filters. Is there a way to disconnect the amps from the DSP/DAC board so I can use a PC and DAC to the amps directly?
Yes via a pre-amp, unless your DAC has a volume control. See the relevant application notes from the Hypex website for your amp module for connection details etc.
Hi Folks,
There was a question in Jan 2019 asking if someone had already come up with a display of the preset and/or source and/or level for the Fusion amps.
Before getting my hands dirty on that (mainly for the preset as far as I am concerned), did someone already try something since then ? (I would guess through I2C)
I've been thinking of gutting my FA253's and reuse the amp modules (basically build an Apollon) and use it in connection with a minidsp 2x4hd for much the same reason.
It seems perfectly doable but it would be interesting to hear from somebody who has tried something similar.
Yes, it would solve many problems for me. The fusion would have worked if it wasn't for the inability to manage phase as my mid driver drifts to 90degrees out by the frequency I would like to cross over at. Add this to the phase changes of a 4th order LR crossover, and the crossover doesn't work. I don't want to EQ it up, as off axis it may be more in phase and hence louder.
If you have phase problem between your drivers, then there is either frequency response or timing problems or both. Both can be fixed within HFD, and if you solve the those two aspect then the phase problems is solved.Yes, it would solve many problems for me. The fusion would have worked if it wasn't for the inability to manage phase as my mid driver drifts to 90degrees out by the frequency I would like to cross over at. Add this to the phase changes of a 4th order LR crossover, and the crossover doesn't work. I don't want to EQ it up, as off axis it may be more in phase and hence louder.
Or did I miss something?
Of course there is only limited slopes which works as in-phase crossovers and flat frequency response with IIR or analogue filters, these are the Linkwitz-Riley slopes.
The driver rises in phase as the frequency lowers
Here is the raw driver on the horn with no crossover etc
Desired crossover point is 500hz to bass driver.
2452H + JMLC 350hz RAW phase.jpg - Google Drive
- Class D
- The New Hypex Fusion Plate amps
