Hi yes, i found it after i posted, in haste btw, and apologize.
I'm really looking forward to this build, I'm building the B1 Korg and the Aleph J after.
Thank you for the link!
Just for fun, I dug out an old 2x30w hypex class D kit I built some years ago and intended to use as summer amps for my Altec A5s, instead of the 300b SE and Kt88PP valve monoblocks I mainly used before DIYing First Watt amps. There is no buffer in front of the Class D, but I used a small Sowter trafo to convert from single-ended input to balanced. They sounded quite aggressive with my simple autofomer passive pre and did not have enough gain. Yesterday I tried them with the B1 Korg in front and the combination was much better than expected. No aggressiveness, no overly dry bass with the Altecs. All inn all quite good.
The B1 Korg is a wonderful pre.
After I used Staving Student II as preamp for a while I have now switched back to Korg and I must say it is very nice sounding. Combination: Korg + M2X (Norwood) + OBL-15 is very nice. I remembered to swap speaker outputs at M2X to get correct phase (and 2nd harmonic negative phase).
The setup if perfect for "real" music like acoustic music, live music, classical.
It is not that good for electronic music and music that has got a lot of "makeup" to enhance bass response etc. But that is not my kind of music anyway.
Thank you, i got the kit but there are some missing parts, this should help pinpoint what else i need and then hopa onto building and coupling with a marantz amp
I may have blown out something in my Nu tube pre-amp.
If I short the output of the pre amp, do I burnout the output buffer??
Tubes are still lit...
Just finished my B1 Korg Triode!
Sound is great, fed from my Allo Katana DAC (powered by Salas UBiB shunt regs), through my Salas Mesmerize DCB1 as input selector/buffer, and the B1 Korg serving as input buffer for my F6.
Nice job!!!
OK, I could use some help.
I built the full kit about 3 months ago, but have been having problems with it ever since. I've been double checking polarities and values ever since.
I get the correct in-spec voltages for T1-T6. When it is first powered on, I also can adjust T7,T8 to around 10 volts. I let it sit to warm up, but after a minute or so, T8 starts dropping, eventually going down to about 3 volts. I've left it on for 24 hours, and it still stayed at 3 volts. Also, it's side of the NuTube doesn't have that nice blue glow.
I used to have this problem with both T7 and T8, but now it seems to be confined to T8.
I've put an oscilloscope probe on T8 and noticed it is quite noisy and unstable.
Does anyone have any ideas on what to check next?
I think I solved the problem. I removed the NuTube, removed the solder and cleaned the board, and then reinstalled the NuTube, this time soldering it in from the opposite side of the PCB. The PCB pads on the bottom of the board may have been contaminated initially or just weak and not making a good connection, even with my Metcal solder station.
If anyone else is seeing their T7,T8 voltages drift downward, they might give this a try.
The Plate impedance of the Nutube is very high, so any space between
those pins and elsewhere needs to be free of even remotely conductive stuff.
Good to know, and probably a good idea to add to my best practices list.
Thanks!!
I also use Hypex with H2 (not KORG) with JBL 15" woofers. I think low frequency control of Hypex is too lean/tight for 15", and adding H2 makes them sing a little better. 🙂
My Pass B1 Korg NuTube has been alive now for 15 months with regular use, listening to it now as headphone buffer, bless its little blue green heart.
I've very kindly been offered the Loan of a Third Version of the Build of the
B1 Korg Nutube by an Individual who has produced two other boards and mentored on two builds carried out by friends.
There is a B1 Korg Nutube admiration taking place within my local HiFi Group.
I'm very much looking forward to experiencing this Device in my system as the loan is for the long term and will commence from tomorrow 🙂
There's a big batch of them on their way to the store.
I hope those are the kits already!
I've been dying waiting for them since 😁
There is only one or two volts over them - no problem.Hi, despite the qualities of BG caps I think using 6.3V electrolytic caps in the effect generator is not a wise choice.
Hey guys a quick question and I guess I read this somewhere on this long thread but unable to find the information.
On the store B1 Korg boards for the jfets, there are 2 positions marked as JQ1/KQ1 for 4 of the Q1 and another 4 for Q2 transistors. I believe the jfets which came with the board in the store kit provided should go into the JQ1/JQ2 positions right and leave the K position open?
YesHey guys a quick question and I guess I read this somewhere on this long thread but unable to find the information.
- B1 with Korg Triode
