Something to lighten the mood
This was the best deal I could find on the web for food grade.
Thanks to the metric system mixing is easy. 700ml alc. + 300ml water. 😀
Water and ethanol form an azeotrope, so simple distillation only gets you to 95% ethanol, or 190 proof. Back when i was taking my college chem and microbiology classes we were taught that benzene was added to 190 proof alcohol which was then re-distilled to get to absolute (100%) ethanol, and since benzene is carcinogenic drinking absolute ethanol was verboten. The 190 proof stuff was safe. Not that we would have ever drunk that...
So how do they get 200 proof food grade alcohol? Different, food safe ternary additive?
I can't imagining you taking worse pictures of that wall. Next walk, maybe morning shots instead of the afternoon? 😉
200 proof ethyl alcohol
I think you're going to get comments about that.
Hard to get that high given how quickly water from the air gets sucked into it.
I had a feeling.
Do you add anything like aloe as a moisturizing agent for your hands?
No, I don't actually make anything like that, it was a joke. This is the something to lighten the mood thread. I use either isopropanol or methyl hydrate that I have plenty of. Splash it all around and hope some soaks into my skin. My day goes better that way and my wife can never complain.
I have found that I’m becoming more food-centric lately, looking forward to meals more enthusiastically than usual.
Ya, no sheep dip batman. I used to look forward to sex. Now, since I am all worn out, it's a steak and a hair cut to turn this guy's crank.
Except that 100% evaporates very quickly and optimal contact to kill the virus is 20 sec. minimum. 70% sticks around longer and is still strong enough to do the job.
if we are talking abou tCovid-19, high test send sit into a protective mode and doe snot work that well, 70% “melts” the protien skin and the virus becomes unhinged. Not as well as soap thou.
dave
