Cathode Follower, again
A few years ago I listened to a preamp at an exhibition that impress me for good sound quality ... schematic was roughly the one on the right ... I couldn't find any feedback on the net and I don't know if I understood the meaning of it. .. I still tried to adapt it with different tubes and new parameters ... what do you think about it?
...i forgot: pre provided Vg p-p 4v
Any tube will do in that position, a cathode follower is a topology that doesnt provide "colour" to the sound, you could even put a wimpy 12ax7 (requires changing cathode resistor like any other different tube) because the driver requeriments of a 6y6 in that configuration are not very high, if you have 6n1p, 6n6p, 12au7, 6sn7, ecc88 variants they will all be equally good in that position.
But isn't it always better to use a valve like 6S19P which is more suitable for impedance drop?
I was also wondering if this circuit has a distinctive name in English ...
I think you are confusing two different topologies the low impedance of the driver in the circuit you put has no other use but burden the heater and HV supply.
The AC coupled output stage is indeferent because it doesnt need that low impedance to work properly, if it were a A2 it would, but like your diagram shows it won't notice if its a mosfet or a triode, you only need a couple miliamps of standing current to cope with miller capacitance to have good HF response, in A2 class you will need a low impedance driver to cope with the grid current when signal goes positive over cathode, nevertheless the design of the driver stage and the selection of the power and driver tubes in a A2 SE isnt as trivial as an AC coupled SE.
The question you were asking was not so clear to me. It's the preamp you want to build? And you want to use less expensive tubes? You can use any 6DJ8 variant on the front, including 6N23P. The 6AS7 is already inexpensive. I'm not sure if there is a new production equivalent; I think maybe a 6C41C is maybe a good choice.
in fact I still have as much confusion, ac or dc coupling, as it is essential to have a low Zout and a large reserve of current.
No, I would like to build something similar to the amplifier which is on the left. I would also like to compare it, with the same wattage with the pentode version with a single tube that I already built. I took as an excuse the scheme of that pre to try to imagine it inside the amplifier. Reading the explanations of the person who designed it, I persuaded myself that it could be a good solution also in the future perspective of other projects.
As for EC86: it has a lower commercial value than the 6DJ8 standard and, with the same construction quality (for example with an E88CC SE), a price 10 times lower.
