TDA7498E don't produce any sound (red Amplifier module)
yes
No it will not damage your speaker (you measured with GND, it shows +ve DC volt on all speaker line)because your SPK not connect with GND (it's BTL mode only)
Hi my dear NANOJ, i hope you have an nice day.
I will try replace this capacitor.
I measure the outputs terminal from the speakers (L+ L- / R+ R-) and the voltage reading is not mvolts, is volts and my speaker i test it smell like burning, why?
It's all connect the right way, can you explain me what's happen?
Best regards.
Hi . I have the similar problem with a red board sanwu 7498E.
It doesnt make sound. No parts burned. No D8 diode...
Cold you fix it?
I will try to meassure the pins of the chip with voltimeter, but they are so small. Any tip to do that?
Sorry, I am a 39 years old beginner in electronics 🙂
I also have a 7498 with no sound. Any fixes guys. Some pics of mine. Tested 9-24 volt still no sound. Bought a year and sat there till 2 weeks ago. Contacted the seller to see if he has any advice. I'm sure it's too late to get it replaced.
I return to the subject. When I removed the heatsink from the red 7498E board, I saw that the circuit was a 7498 without E. The seller gave me my money back. I ordered another 7498E board, this one is black and it doesn't sound either 🙁🙁 (they also gave me money back).
I feed it with a 90W 20Vdc laptop power supply, speakers are 6Ohm 60w
No things burned. Led power ON.
I have changed the gain jumper for 33.1db (by default) to 23.6dB, same result.no sound.
Measurements (and photo with points were I'm metering, same as 7498E pins):
20: 2.9V
21: 2.77v
22: 0.02V
29: 0.8V
*note: the voltimeter I have now is a little bad
Should I need change pin29 capacitor 10uF?
check PIN 20 & PIN 21= 3V if yes then replace 10uF capacitor (SMD) connected in PIN 29 to GND
MANOJ
Do you know other points to test it?
Could you do change it?
Thank you in advance
more measurements:
pin 6-7 (PVCCB):21V
pin 12-13(PVCCA):21V
pin35 (SVCC):0V
18 (PGND)0V
19 (VDDPW)= 0V
20(STBY): 2.9V
21(MUTE): 2.77v
22(INPA): 0.02V
29 (SVR) =0.3V
34 VREF=0,15V but its decreasing connected with the voltimeter
36 VSS=0v
may be 7498E broken?
