"...will have lower operating temperatures and lower thermal noise as a result."
That makes sense. I was trying to get a handle on this on another thread (or two). For phono preamps and MC pre-preamps low noise is important. I would think that using 1/2W devices would be preferred if there was room on the board.
The general advice has been that Vishay/Dale have the lowest noise. But at 0.1Uv/V is it that much lower than, say, Takman's 0.3uV/V and in a meaningful way? Or PRP's -30db? (according to them). Or the -42 db of the near-unobtanium-grade naked foils Vishay TX2575?
And I expect there are other noise mechanisms -- other than thermal -- at play that have pundits and salesmen waxing poetic about "warmth" and such.
Finished mine after a 6 week wait for a transformer.
Still need to put it in a box.
Two records in and im going to enjoy this pre-amp.
Isolation by plastic ono band sounded great.
Photos to come when in a chassis.
Thank you Oliver.
Thank you Oliver.
That's great news. Really pleased to see these builds getting completed and most of all, being enjoyed.Finished mine after a 6 week wait for a transformer.
Thank you Oliver.
That's a DC blocker....stops DC getting off the mains inlet to the transformer and making it mechanically buzz.What is the extra board doing?
I have been asked about where to buy the transformer so thought I'd post here.
I have been using Audiophonics.fr for my transformers for some time but they take forever to arrive.
I have approached a few transformer companies in the UK to try and find an alternative route into buying small quantities of Toroidal transformers.
If I get any joy, I'll share it here.
Oliver, did you find replacement for Audiophonics.fr?
I received my boards today, now I am looking for a transformer, Tiger Toroids quoted £50 (transformer) + £40 (shipping) - pricey. I am considering getting this one from ebay: https://www.ebay.com/i/192498606475...DQOvd7aLpwsnxHKdVnbKICbD3s88fjYxoC-RgQAvD_BwE
but not sure about quality...
I have never used one personally but a good few have and reported no issues.Oliver, did you find replacement for Audiophonics.fr?
I did order an EI transformer from Chinese outfit, but I dont recommend them for one box builds.
Need to get them far far away from the PCB.
Toroidy.pl make really nice transformers.
Other than that, I think taking a punt in the one linked wont hurt..and a R core is a decent traffo.
It's cheap enough anyway.
I received my boards today, now I am looking for a transformer, Tiger Toroids quoted £50 (transformer) + £40 (shipping) - pricey. .
Where are you based? If you're in the UK I have a contact at Tiger and may be able to get you a better deal on the postage.
What if the AC input to the HV is 230v-0-230v and I only have 0-230v AC.
How do I connect then?
Common the centre pair as it were. Pretty sure the ebay ad shows you this if you look at the detail.
Yes it's a 115 115 traffo so you have to common the centre pair, this gives you 230v input.Common the centre pair as it were. Pretty sure the ebay ad shows you this if you look at the detail.
There is a wiring diagram on the traffo and it is pretty easy to check with a Multimeter....once someone tells you how to do it lol
Thanks, but I am in US 🙁
Ok figured as much, agreed not a lot I can do with that distance...
Observation from the cheap seats:
I've been mostly just monitoring this thread so I don't know the precise requirements of the transformer but I've seen descriptions of custom units with multiple outputs.
Why not get two transformers, one to handle each voltage?
In the States Antek -- Transformers - Page 1 - AnTek Products Corp -- seems to have a reasonable selection that might serve to keep your project going.
Just a thought...
Just a thought...
Just a thought...
yeah, I was thinking about this as well, although I couldn't find transformer with 165V secondary...
Youd have to have it custom wound, which probably doesn't save you a while lot in all honestyyeah, I was thinking about this as well, although I couldn't find transformer with 165V secondary...
I use them religiously.Would people recommend using tube dampers on the valves? If so what sort? tia
I found silicone ones.
- Analogue Source
- Bigbottle Phonostage Builders thread
