Aleph J illustrated build guide
Thanks for the great explanation. Very helpful. Even though the amp excels in its musical abilities, I still want to explore methods of reducing the noise, possibly trying a hum-breaking resistor on the input ground as an easy experiment.
The hum-breaking resistor will help a lot. It eliminated the hum on my Aleph J.
This choke could work as well, to reduce the hum on DC rails. 159ZJ Hammond Manufacturing | Mouser Australia
Hi, guys.
I have some trouble with my Aleph j.
Everything was great one week ago. When i came back from business trip, i switched it up and heard noise in the left channel tweeter.
I have measured bias and offset in both channels. Bias is ok. Right channel offset is constant (2mV). Left channel offset is dancing from -8mV to 6mV and it always changes. I think it is the reason of the noise, but who is guilty for it? Offset variable resistor? When i rotate it, offset changes with jumps, not smooth.
The noise has variable frequency and volume level. Like a wind.
Please give me an advice, how to fix it. JPEG_20200523_115202_2042482330747765759.jpg
Unfortunately, I have checked the trimpot and it is ok.
How can i check if it is CCS oscillation?
I see two ways to solve oscillation problem:
1. Replace Q2 from ZTX550 TO BC560CTA
2. Install R6&R30 resistors instead of jumpers.
What are the correct values for R6&R30?
I have some Aleph 30 boards that I built many years ago and since removed for another build. I want to build an Aleph again, preferably the Aleph J but the store is out of boards. I distinctly remember somewhere on this forum Nelson telling how to convert the Aleph 30 over to an Aleph J but I have no idea where to find it again. Anyone have a better memory than me?
I believe so, many thanks. I just figured someone has a better memory than me. I built the Aleph 30 many years ago and since then I like to believe that I have better skills now especially matching the output mosfets. I did notice comparing the Aleph 30 vs the Aleph J that the damping factor is much higher with the Aleph 30 than the aleph J. I think that one thing that improves the damping factor is the 6 output devices per channel. Converting my Aleph 30 to the Aleph J may produce the best of both worlds.
