My_Ref Fremen Edition - Build thread and tutorial
the first My_ref amplifier alive and well ,with almost all evolutions and your modifications in fifteen years!
Great sound with shunt power supply , but not so easy to upgrade in this old board
A way to keep your mind busy in this unhappy moment.
Fixed
In a previous post I reported the sound signature what not at all as expected. Today I'm breaking in the speakers and indeed the bass starts to become more present. But still nothing close to what I was expecting.
Started going over the build guide again and found my mistake: I soldered C10, but not R39 :headbash: .
Removed C10 and there it is! The My_Ref Fremen the way it is supposed to sound. I can reconize all my songs again 🙂.
For learning purposes: can someone explain why C10 without R39 has this impact?
Which compensation scheme are you using? FE or Evo A? 😕
No C10 and no R39 points to Evo A but then R3 MUST be 0.33R, which value do you have there?
BTW, yes omitting or changing compensation parts could have a BIG impact on sound (and STABILITY).
No, just replace R11. It connects the input ground to the power/output ground.
So guys...
It seems that I'm very lucky man and the schematic is well done :worship:
Replacing R11 with equivalent res and with fly connection, everithing works fine and I'm able to hear the music :cheers::cheers:
Now I have to order the right res...
I hope that next week I can post my impressions on both channels run 😀
Pardon for trolling but here it is.
2006....
Ps: George might realize some 'features' - - and Mauro is rolling in his rest..
By the way, in the photo R3 is an ATE 5CS wirewound resistor. It's the Ayrton Perry wound variant, but I have to say that later I changed to the standard ones simply.
I find these very nice, still today. Even against / beside the Isabellenhutte PBH ones.
Did You get them?
G
Not smart enough bough to my rder
Did You get them?
G
I have tried using Google to place an order. I am not getting it. These translation codecs are vague on items. Have not gotten an account yet for the same reason.
I have often used these resistors in speaker crossovers. Ate CS is a normal wound resistance. If you want the Ayrton Perry anti inductive winding you have to order the CSN type (the suffix N is the key) and generally they must be ordered at the factory. In Italy the Ate SCSN are on sale from Audiokit, I don't know if they ship in the USA. A 0R33 costs € 4.67 plus shipping.
Ciao a tutti
Giacinto
Probably this can be a very stupid question...
For the input signal I buyed a balanced cable van damme 268-006-000.
Which is the best way to connect to CMC-805-2.5-F?
I found on google that I have to solder together the cold pin with the shield. Is this the correct way or I have to leave the shield unconnected?
C10 on ver 1.05 boards
Dario: I’ve acquired a set of Ver 1.05 PCBs from someone and want to build a basic EVO A version. The BOM for "up to 1.2" has C10 occupied with a 33pF CDE cap. Is this correct? The BOM for my Ver 1.7 PCBs had C10 unpopulated for the EVO A build.
Also, will your new PCB version have the ability to mount TO247s at R3?
Many thanks,
Pete
