Western electric compression driver clones
I have had a chance to hear a WE full system with original WE15. It's one of the best audio experience in my life, but all they played with it was old music before 60's (Maybe before 50's). I don't think they would sound good with modern music, but I don't know. Honestly, it's funny for me to compare it with modern short waveguides. It's better to listen to it before you start building (or buying) WE horns. I have no idea how good the clones are. They do "look" good, though...
Reactions: David Whistance
Yes, as part of a system they can do big orchestral recordings and massed choral works like no other. Also good at smaller scale recordings and giving an amazing sense of real people playing in a real space. As for Prog Rock, can't say that I remember. My guess is yes, but it may not be the presentation you are used to. For me, Rock depends on big powerful sound systems that are not natural sounding. They sound fun, but not natural - like bigger and louder than life with way more bass. 🙂
Since I would not use a horn like the WE-15A without woofers, your woofers and woofer amps could be the make or break it for Rock.
These are not horns for small rooms, I hope you realize that.
I had a feeling that this euphonic sound of WE horn is largely due to its metal material
Only the first part of the the throat is metal. The horn is made of plywood. I think that the double 16A might be metal but I have not seen one in person. The Vitaphone 11A is also wood - a scaled down 15A. The WE-15A and similar horns are not "euphonic" if you use them right. They are accurate and true to life.
A horn the size of the WE-15A should be part of a large system in a large room. I would suggest 70-150 square meters with high ceilings. For a smaller space then something like the Sato horn would be better suited. Although if building from scratch I would not bend it so much.
Good day
I decided to give this project a try
It will be something like system 6 by WE
Driver will be Lamar audio m1, as every other option is much more expensive
1.45x1.45 meters horns will be definitely too large for me. So i will stop around 1 meter mouth opening.
Driver throat diameter is 18 mm, screw type( like original WE).
I need horn that is able to be crossed at 200hz.
Sato horn seems good but it is for 2`` throat. Can you recommend something suitable for 18mm thoat?
Apparently, Lamar was early with carbon membranes or glass fibre? Correction, Carbon membrane with glass fibre surround!
