100W Ultimate Fidelity Amplifier
The other way to do the same APEX AF14 🙂
  • APEX AF14 components.pdf
  • APEX AF14 Layout.pdf
hi friends,
i finish f100 psu and put on ax14 . its working nice and good not hot but warm. but there is one little problem i have and cannot fix it.
when there is no sgnal i getting humm. but if i connect my radio and put volume half on it that humm going away or i dont feel cause of the music i dont know. maybe humm coming from bad grounding i check it but cannot see any problem. it can take noise from air?
or maybe my schematic wrong one?
please help any idea can be important..
dc ofset 2.6mV
power + - 47VDC
bias at 0,33ohm resistor is 10mV
where do i need to look for that problem?
note: yes i did make input gnd to psu gnd, out gnd to psu gnd,
here is a version of above quoted crc with either CT trafo or dual secondary trafo. though slightly larger at 95 mm x 99mm, it can now take up 35mm caps, 6 x 3W resistors or 2 x 5W resistors.
The center bridge to be used only when CT trafo is to be connected.
regards
prasi
Having some fun with Autodesk Fusion to create 3D models, here are some images😀. Earlier 3D's from sketch-up were too drab😱.
its the compact CRC PSU PCB with ability to use either CT trafo / dual secondary trafo of the quoted post😛
regards
Prasi
FX11
Hello
greetings lockdown time decided to try to improve FH 11
1 INPUT TRS 2SC1845
2 Driver trs 1381/3503
3 Offset preset added
4 T6- 2sc1381
5 2 in4148 diodes added
6- MPSA92 in series as suggested by apex audio:whazzat:
Warm Regards
Andrew
hi friends,
dc ofset 2.6mV
power + - 47VDC
still cannot fix it 🙁
if i short input then humm going away i find its coming from input cable i change and use shilded cable too but still same just drop noise a little. i remember i was have same problem 1 year ago again on same amp i think there is some thing i doing wrong.
what can i do please any help can be powerfull.
thank you.
