I am glad the pcb’s arrived after all this time.🙂PCB's just arrived!!!excellent quality!!!
Keep us posted on your build.
Fab
Thanks Cambe for the notice. Now let the journey begin.🙂Fab,
PCBs and Output Transistors arrived safely.
Thank you.
Fab
Hi Oracle1
It has taken 2 months for Nanakos who lives also in Greece. I guess the long time is an effect on postal service due to the Corona virus...🙄
Fab
Fab
Finally.....
At last... Like Etta James,
The pcb's are here.
I am very exited, but now i must find time, because the vacation has ended and the time is the most valued think....
The pcb's are here.
I am glad you finally get the PCBs 🙂
Even with the virus situation it should not have taken that long...🙄
Yes, time is the essence...
I suppose you got plenty of time to order the pcb components😉
Good luck.
Fab
Good luck.
Fab
While I am procrastinating to start building the USSA5, I stumbled on two things regarding the USSA5 design:
(1) What is the purpose of R15 and R16 (referring to the schematic here: https://fabaudio.online/ussa-power-amp ). Are those resistors really necessary with the lateral MosFETs?
(2) Just as a thought experiment: let's say I want a balanced input, and I like tubes. Would it be a bad/crazy/wrong idea to replace the input stage with a long tailed pair of triodes? I know this would be a different amp, and I am not saying that I will do this. I am just enjoying the thought of this and would like to see what others think.
Ok, I need to finish the headphone amp that occupies my workbench so I can get started with the USSA5...
1) Good point. R15/R16 purpose is for the specific output stage bias current measurement during the build. It also acts as very small local feedback. It is true that lateral mosfet do not require source resistors which also allows more square law effect. As a compromise I target both aspects (bias current measure and square law effect) by using a very low value (0.05 ohms) source resistor. You can also use an even lower value such as 0.02 or even 0.01 ohms ( however measurement will be less accurate at such low voltage with a standard multimeter). If you replace R15/R16 with jumpers (0 ohms) then you can also mesure PSU current and subtract input and driver stage bias currents. I find it more convenient to measure directly output current alone using resistors. In the FSSA amp which uses also lateral mosfet, the latest modified BOM indicates 0.01 ohms ( orignal was 0.05 ohms) for the same resistor purpose.
2) I suggest to first try the original version ( but you can use 0.01 ohms as source resistor) and then afterwards build another one with variations. Have in mind that USSA-3 amp uses the famous SK170/J74 jfet as input stage which gives excellent sonic...your pcb is also suitable for USSA-3 😉 with USSA-3 you can even adjust H2.
Long tail pair would be no more an Ultra Simple Symetrical Amplifier ..😉
Fab
Fab
Hmm, why not? Take a look at the balanced input of the Baby Huey, which uses an LTP input stage: Baby Huey PP EL84 amplifier
Looks pretty symmetrical to me.
- Group Buys
- USSA-5 PCB GB
