XSim free crossover designer
Joined 2006
Hi bwaslo
Just finished building a new loudspeaker.... A three way with SEAS Tweeter, Audax mid and CQuenze bass.
For measurements I used REW with it's mic UMIK-1.
The frd zma files were extracted and input in XSIM..... after several interactions I was finally satisfied with the sound and made a final measurement with the filter in place....
The resulting file corresponds really well with the calculated response... this combination of software is incredibly precise.... Thank you very much for your work
Joined 2006
Hi Tom
Please read the LIMP user manual on how to build an interface rig to connect your PC to the loudspeaker for impedance measurements.
After building the interface rig you can use it with LIMP or with REW in the same manner.
  • LIMP-user-manual.pdf
Hello
I use Xsim for the first time, and I'm trying to do quasi 12 db (quasi second order) series 3 ways crossover, crossover frequencies at 150 hz and 2500 hz, but I have few difficulty to succeed. I include the Xsim simulation file, anybody can help me ?
Thank
Bye
Gaetan
  • sc3way-3.dxo
like the function in vituixcad, would it be possible to implement same function so one only need to click on a component and use the mouse wheel to increase/decrease its value, this works very nice in vituixcad and speeds up the manual crossover optimization work :)
It's been in Xsim since the beginning, left click the component, click tune.
All the values in Xsim can be rolled up and down with the mouse wheel.
Administrator
Joined 2004
Hmmm.... I can see how that would be easier, it's a nice UX trick
But more important to me would be something mentioned earlier. Getting back to the value I started with - I can rarely remember, so have to write it down. Not sure how the original value could be indicated, maybe it would turn red or bold or both. Then when you scroll past it again, it would be easy to see it was the starting value.
yes, but vituixcad works slightly different. with vituixcad you just mark the component (one click) and then using the mouse wheel. so with vituixcad there is less clicking and therefor it is little faster :)
Why can't we discuss by e-mail or in VituixCAD thread what bugs you in that program or me so much that you want the same features to XSim? VCAD already has 50x more "everything" so why should bwaslo repeat the same work? Bill is also free to comment about his plans.
As long as the XO circuit is not crazy convoluted and involves countless of parts, I often start with a simple XO, keep it on the canvas but removing the leads, and try to come up with a better one if possible.
Then, to see the differences, I use the Hold button, and switch the leads between the two.
Easy enough.
I'm fie with how XSim works. To me, it's a good combination of features and ease of use.
i like using both vituixcad and xsim, each one have their strengths, so i often use them both simultaneously. one thing that i like with vituixcad over xsim is how you mark a component and using the mouse wheel, it is so fast and simple. with xsim i need to right click and then choose 'tune' and then use the mouse wheel. but many times when this is done and i happen to move my mouse while using the mouse wheel then the 'tune and select' window shuts down, so i have to repeat right click the component, choose 'tune' and...
so this is not a criticism but a wish on my part
