USSA-5 Build with Review
attachment.php
My actual progress 😎
Thanks. More progress... Banana-yellow heat shrink tube :clown:!
Q1/Q2 and Q3/Q4 are matched with 2,8% and 4,9% per pair 😎.
attachment.php
Now I'm waiting for the power transformer to arrive 🙄...
Nice build. You may try the Quasimodo-rig and populate the snubber pads on the boards, too. It's a noticeble difference (less harsh and cleaner midrange).
Snubber shouldn't make a difference on the LT4320 as it does not use diodes, so there should not be ringing. I know it does on the diode bridge. I have another LT4320 that I've setup on a class AB before making the change on this one and I could not tell a difference between snubber and no snubber on that amp. So I desoldered the snubber as I've been told it is not required on ideal bridge.
Do
Is your transformer from Toroidy in Poland? If so, I think you will be pleased. I have had excellent quality transformers from them in the past.
I’m waiting on 2 quiet fans for mine. They are supposed to be here soon. The fans I have in it sound like a small helicopter is in the amplifier. Not nice in my quiet listening room.
