Musical Fidelity X-A50 monoblock amp Circuit
Its very small housing. It didn't have these problems before from new!
Should I change C5? It measure fine with my meter.
Also what about the 3v0 diode. It says 3v0 Zener added mod sheet
What meter you are using for capacity measure?
Zener is there to protect bias voltage rise over 3V, not necessary by my opinion.
ELKOs are always good to change in old devices.
My advice is to change it all, often is not obvious but capacitor is totally defective.
you can temporarily remove C10 and C5, solder C10 to C5 location(+ to resistor R5) to see if it can solve
Do I do MF1 or MF2? thanks
